UCCX V5.x to V8x upgrade question
Jul 14th, 2010
Hello All,
I will be upgrading my UCCX v5.0(2) to v8.x in the near future and am trying to find out if there is much difference in the agent desktop interface? I'd like to prepare the end users for changes in the CAD interface if there are any. Has anybody moved to v8.x yet and if so, could you advise on any differences the agents may need to be aware of in the 8.x agent desktop?
Thanks!
Paul
Michael Turnbow Fri, 07/23/2010 - 17:23
  • Cisco Employee,
Hi Paul,
Major changes between the versions are more feature driven but the operation and look remain basically the same.
Feature Changes:
Extension Mobility Cross Cluster
        Enhanced Cisco Agent Desktop extension mobility support to include telephone devices registered across a CUCM cluster.
Support for CAD to XMPP Gateway
        CAD and CSD can communicate with the new XMPP-based Cisco Unified Personal Communicator via the CUP XMPP Gateway
Independent Client Configuration Package for Automated Deployment
       Agent, Supervisor, and Desktop Administrator installation files (MSI) are available independent of the server installation. These are configured using an MSI utility that can be executed from a windows PC
You can find the documentatation for the agent desktop here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_8_0/user/guide/cad80ccxug-cm.pdf
For your reference the CAD 5.0 documentation can be found here:
http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_5_0/user/cad/cad64ug.pdf
Hopefully this helps you make your decision.
