Nested parameters within CVP Applications
I have a ICM 7.5 with CVP 7.0 environment and I am currently having an  issue where I am using the canned Webservice element in a VXML/Studio  application and it is failing to pass session variable data to the web  service in the "Request" although the same data is able to pass if it is  hard coded in the "Request" section.
The issue appears to be not a web service issue since the hard coded  data is working.
When dynamic session variables are nested within applications is the code somehow altered that prohibits webservices from funtioning normally?
Why would hard-coded variables work?
Thanks in advance.
