C6509-E Questions
Answered Question
Jul 14th, 2010
I am building 2 6509-E chassis that will have dual supes with the following modules and I have a few questions about them:
VS-S720-10G-C
Does this already come with the MFSC3/PFC3C
WS-X6548-GE-45AF
Does this already come with the WS-F6K-AF card
What is the difference between this and the WS-X6148A-GE-45AF line card
WS-X6708-10G-3C
Does this already come with the WS-F6700-DFC3C card
Correct Answer by jorge.calvo about 6 years 9 months ago
Regarding the difference between WS-X6548-GE-45AF and WS-X6148A-GE-45AF, one of the most important differences is the forwarding architectue:
- WS-X6148A-GE-45AF is a classic line card that uses the 32Gb shared bus
- WS-X6548-GE-45AF is a CEF256 line card
More differences are the maximum Jumbo frame they support and their port buffer size:
- WS-X6148A-GE-45AF: Jumbo size up to 9216 bytes and 5.5MB of port buffer size per port
- WS-X6548-GE-45AF: Jumbo size up to1518 bytes and 1.4MB of port buffer size per 8 ports
Hope this helps.
Correct Answer by Reza Sharifi about 6 years 9 months ago
VS-S720-10G-C
Yes it does.  BTW it is VS-S720-10G-3C
WS-X6708-10G-3C
Yes, it does.
WS-X6548-GE-45AF
Yes, it does.
When you order using Cisco configuration tool you will see some items that have value of $0 and those are the cards that already come with the sup or module
for example the below part number comes with SUP-720-VS and has a $0 vlaue
CiscoVS-F6K-MSFC3Catalyst 6500 Multilayer Switch Feature Card (MSFC) III$0
Reza
Overall Rating: 5 (4 ratings)
Correct Answer
Reza Sharifi Wed, 07/14/2010 - 16:26
  • Cisco Designated VIP,
    2017 LAN
VS-S720-10G-C
WS-X6708-10G-3C
Yes, it does.
WS-X6548-GE-45AF
Yes, it does.
Reza
Correct Answer
jorge.calvo Wed, 07/14/2010 - 22:53
  • Bronze, 100 points or more
Hope this helps.
Amit Singh Thu, 07/15/2010 - 14:04
  • Cisco Employee,
I am not sure if this might be of interest but you Sup engines are VSS capable. However, if you configure VSS in future, the classic cards like 61XX and 65XX are not supported in VSS configuration. The line card will not power up. Make sure you are aware of this if configuring VSS in future.
HTH,
-amit singh
rzulueta315 Thu, 07/15/2010 - 14:47
In that case, what line cards are available to me if I implement VSS in the future?
Reza Sharifi Thu, 07/15/2010 - 14:53
    2017 LAN
With VSS you can not use 6548-GE-AF (POE cards).  But you can use 6708, 6716, 6548-GE.
VSS is intended to distro layer so it is assumed that you are using POE card at the access layer
Reza
Reza Sharifi Thu, 07/15/2010 - 15:51
    2017 LAN
Amit,
My apologies, that was a typeo from me.
Thanks for clarifying
Reza
