CSS 11503 http redirect / rewrite to https ssl with wildcard cert
Answered Question
Jul 15th, 2010
I am trying to get all my traffic  for http VIP send to https on the same VIP. I have managed to do this  with with a single a record but my problem is that I have a wildcard ssl  and want to be able to direct incoming http to https and keep the  address information.
i.e.   http://test.domain.com to go to https://test.domain.com and
       http://newtest.domain.com to go to https://newtest.domain.com
I have  around 30 subdomains and do not want to have to write rules for each  subdomain to be redirected.
My configuration looks like this at the moment and any  light would be greatly appreciated
  ssl associate rsakey domainkkey  domainrsakey.pem
  ssl associate cert domaincert domaincert.crt
  ip  route 0.0.0.0 0.0.0.0 192.168.33.1 1
!************************* INTERFACE  *************************
interface  3/1
  bridge vlan 33
!**************************  CIRCUIT **************************
circuit VLAN1
  ip address  192.168.35.1 255.255.255.0
circuit VLAN33
  ip address 192.168.33.2  255.255.255.0
!***********************  SSL PROXY LIST ***********************
ssl-proxy-list ssl-proxy
   ssl-server 1
  ssl-server 1 vip address 192.168.33.102
   ssl-server 1 rsacert domaincert
  ssl-server 1 rsakey domainkey
   ssl-server 1 cipher rsa-with-rc4-128-md5 192.168.35.5 80
   ssl-server 1 urlrewrite 10 *.domain.com sslport 443 clearport 80
   active
!**************************  SERVICE **************************
service EUHS1WEB20
  protocol  tcp
  port 80
  ip address 192.168.35.20
  keepalive type  none
  active
service EUHS1WEB21
  protocol tcp
  port 80
   ip address 192.168.35.21
  keepalive type tcp
  active
service  SSL-MYDOMAIN
  type ssl-accel
  slot 2
  keepalive type none
   add ssl-proxy-list ssl-proxy
  active
service SSL-REWRITE
  keepalive  type none
  type redirect
  no prepend-http
   redirect-string "https://*"
  active
!***************************  OWNER ***************************
owner domain.com
  content decrypt-http
     vip address 192.168.35.5
    protocol tcp
    port 80
     add service EUHS1WEB23
    active
  content ssl-rule
    port 443
    protocol tcp
    add  service SSL-MYDOMAIN
    active
  content testhttp
    protocol tcp
    port 80
    url  "/*"
    add service SSL-REWRITE
    active
CSS11503#
Thank you  in advance
Correct Answer by pcoughlin01 about 6 years 7 months ago
I don't believe this is possible using a single rule.  See post https://supportforums.cisco.com/message/457788#457788
for more information.  I ran into a similar situation and had to create multiple rules with the same VIP, but different URL's and redirect services (see below)
Hope this helps.
Pat
service redirect-tenant2
  keepalive type none
  type redirect
  no prepend-http
  domain https://tenant2.yourdomain.com
service redirect-tenant3
  keepalive type none
  type redirect
  no prepend-http
  domain https://tenant3.yourdomain.com
service redirect-tenant4
  keepalive type none
  type redirect
  no prepend-http
  domain "https://tenant4.yourdomain.com"
  content tenant2
    vip address 192.168.99.1
    protocol tcp
    port 80
    url "//tenant2.yourdomain.com/*"
    add service redirect-tenant2
  content tenant3
    protocol tcp
    port 80
    url "//tenant3.yourdomain.com/*"
    add service redirect-tenant3
  content tenant4
    protocol tcp
    port 80
    url "//tenant4.yourdomain.com/*"
    add service redirect-tenant4
Overall Rating: 5 (1 ratings)
Correct Answer
pcoughlin01 Mon, 07/19/2010 - 04:32
Hope this helps.
Pat
  keepalive type none
  type redirect
  no prepend-http
  keepalive type none
  type redirect
  no prepend-http
  keepalive type none
  type redirect
  no prepend-http
  content tenant2
    protocol tcp
    port 80
  content tenant3
    protocol tcp
    port 80
  content tenant4
    protocol tcp
    port 80
Glenn R Mon, 07/19/2010 - 05:39
Thank you for your response.
After much reading and head scratching I have concluded that what you mentioned is the only way to be able to do this. The problem I have is that off our wildcard we have 2500 sites i.e. test1.domain.com - test2500.domain.com  and do not feel like typing in a large list for each A record.
So what I would hve liked is not achievable as you mentioned in my situation and I have had to rethink this.
What I have done is change my Apache servers indexpage to redirect to another named page with a redirect rule.
Like follows:
CSS -->VIP for -- http://test1.domain.com/index.php
Apache --> redirect to --  header("Location: https://" . $_SERVER['HTTP_HOST'] . "/newpage.php");
So the switch keeps the VIP the same but just switches to https.
Not perfect but works
Thank you
