07-15-2010 04:11 AM - edited 03-19-2019 01:15 AM
I have a problem with doing a transfer from a CUC version 7.1 mailbox to a phone on the CUCM. Here's how it is set up:
1) User Device Profile with line 2461640 has a Call Forward All to Voice Mail
2) CUC mailbox 2461640 has a standard transfer set up to 8881611 (and the All Hours schedule), with the "Wait While I Transfer Your Call" prompt enabled
When I call 2461640 I am immediately transferred to the Standard Greeting, I do not hear the "Wait While I Transfer Your Call" prompt.
I managed to get something similar working the following way:
1) Hunt Pilot with line 2461640 pointing to the Unity VM ports, replaces the User Device Profile with line 2461640
2) On Unity a Direct Routing Rule is set up to transfer direct calls to CUC mailbox 2461640 with the "Attempt Transfer" option selected
Then it works fine, the call is transferred.
Does someone have an explanation for this behaviour?
Many thanks
Tim
07-15-2010 06:25 AM
Tim,
In the first scenario, CUC is operating as designed. The calls comes into CUC and is treated with the "Forwarded Routing Rules". If you have the default rule configuration, then the first rule is "Attempt Forward" and this rule will attempt to send all calls forward from a user extension to the user's mailbox greeting. This is a key point, calls are sent directly to the greeting and the mailbox transfer rules are completely bypassed.
In your second scenario, you are creating a direct routing rule and specifically sending the call to the transfer rules.
Going back to your first scenario. I suppose you could try the following:
1. Go to the standard greeting on 2461640
2. Config the "Callers Hear" setting to Nothing and uncheck "Play the "record your message at the tone" Prompt"
3. Check "Ignore Caller Input"
4. Config the "After Greeting" setting to send the call to a "User with Mailbox". Select the same mailbox for 2461640, but select "Attempt Transfer".
Then, ensure that your transfer settings are configured to send the call to 8881611.
This setup worked in my lab. Now, you have to careful with the configurations in CUC. If you put the wrong configuration in place, you have a chance of creating a loop. For example, if the transfer setting is sending the call to the 2461640 extension which is configured forward all to voicemail then you would have a loop. Also, there is another loop if the transfer setting is set to send to the greeting for 2461640.
But, if you set it up correctly it will do exactly what you need it to.
HTH.
Bill
Please remember to rate helpful posts.
07-15-2010 06:54 AM
Just to add something to the great advise from Bill.
The transfer settings work for transfers within CUC (attempt transfer, dial from a call handler, select user from directory handler, etc). That's why it doesn't work.
An alternative for what you're doing if the user doesn't need a mailbox as you will send his calls to someone else is to create a call routing rule and set the attempt transfer to the call handler or subscriber where the target is 8881611.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
