07-15-2010 04:32 AM
Hello we've been successfully using IPM 2.4 from Ciscoworks 2000 for last 8 years. We recently migrated to LMS3.1 and all is ok except I'm unable to get the new IPM to work. I think the problem is down to something I'm missing or doing wrong...so if i can describe what we do and then describe how IPM is currently configured perhaps some good soul can point me in right direction to resolving it?
We have a webserver sitting on a server in our DataCentre and it hold 8 pdf files of various sizes.
We configure 42 routers to send a http get request to access each of these files via IPM and we measure response times etc., Reports are generated twice weekly for our customer.
In IPM 2.4 we created 8 different HTTP operations naming them STM-A, STM-B, STM-C...and so on. Each one pointing to a pdf file on webserver on the operation. We create 8 collectors for each router - and each collector points to the HTTP operations created. (hope I'm making sense!!!). We do not use Targets. It all works.
Initially when trying to replicate the settings used in 2.4 i had serious problems getting it work in the new IPM.
First it would not let me create a collector without selecting a target (for this i created a ad hoc target for the server hosting the pdf files). It would create the collectors and i can see them, but it doesn't seem to send the the configurations to the routers (all 1720's btw - but they do work on the old IPM).
I think i got it working once but i couldn't get the reports working....its a nightmare thats been going on for the last few months and i just need some guidance. I can provide screenshots, logs etc., if required.
thanks in advance.
Steve
Solved! Go to Solution.
07-16-2010 10:02 AM
The IPM graphs now use Flash, so make sure you have Flash 9 or higher installed in your browser. Given that the collectors are completing
successfully, you should see data points being drawn in the live Monitor graph. It should take two minutes to see the first point.
07-15-2010 07:32 PM
Creating an adhoc target was the right thing to do. The next thing to do is to create a custom HTTP operation which points to the appropriate relative URL on the server. You can choose to use a custom DNS server, or just have IP SLA use the DNS which is configured on the device. The final step is to define a Collector where you pick the device, the adhoc target, and your custom HTTP operation. If this gets installed down to the source device successfully, but you are still unable to monitor the latency, post the output of "show ip sla conf" from the source device.
07-16-2010 02:09 AM
Thanks for taking the time to reply
After posting, I was able to manually create 8 tests and I could see the tests configured on the routers, but when trying to generate reports it shows nothing. I've also tried the Graph option in the Collector Management section IPM>Collector Mgmt>Collectors but it returns "No data available for the selected time period."
IOS version 12.2(40a) so I'm using the old RTR commands! Not sure if there's a compatability issue with this old IOS and the new IPM but I'm guessing its ok as the configs look exactly the same on the routers when using the old IPM.
PS_xxxxxx_Scarva#sh rtr conf
Complete Configuration Table (includes defaults)
Entry Number: 19573
Owner: ipm|CISCOVMS002
Tag: test_10x.x.x.x
Type of Operation to Perform: http
Reaction and History Threshold (milliseconds): 5000
Operation Frequency (seconds): 300
Operation Timeout (milliseconds): 5000
Verify Data: FALSE
Status of Entry (SNMP RowStatus): active
Protocol Type: httpAppl
Target Address:
Source Address: 0.0.0.0
Target Port: 0
Source Port: 0
Request Size (ARR data portion): 1
Response Size (ARR data portion): 1
Control Packets: enabled
Loose Source Routing: disabled
LSR Path:
Type of Service Parameters: 0x0
HTTP Operation: get
HTTP Server Version: 1.0
URL: http://10.x.x.x:80/OSPF-H.pdf
Proxy:
Raw String(s):
Cache Control: disabled
Life (seconds): infinite - runs forever
Next Scheduled Start Time: Start Time already passed
Entry Ageout (seconds): 3600
Connection Loss Reaction Enabled: FALSE
Timeout Reaction Enabled: FALSE
Threshold Reaction Type: never
Threshold Falling (milliseconds): 3000
Threshold Count: 5
Threshold Count2: 5
Reaction Type: none
Verify Error Reaction Enabled: FALSE
Number of Statistic Hours kept: 2
Number of Statistic Paths kept: 1
Number of Statistic Hops kept: 1
Number of Statistic Distribution Buckets kept: 1
Statistic Distribution Interval (milliseconds): 20
Number of History Lives kept: 0
Number of History Buckets kept: 15
Number of History Samples kept: 1
History Filter Type: none
Entry Number: 38060
Tag: test_10.x.x.x
Verify Data: FALSE
Target Address:
Target Port: 0
Source Port: 0
LSR Path:
HTTP Operation: get
URL: http://10.x.x.x:80/OSPF-A.pdf
Proxy:
Raw String(s):
Threshold Count: 5
Threshold Count2: 5
Reaction Type: none
Entry Number: 117946
Tag: test_10.x.x.x
Verify Data: FALSE
Target Address:
Target Port: 0
Source Port: 0
LSR Path:
HTTP Operation: get
URL: http://10.x.x.x:80/OSPF-E.pdf
Proxy:
Raw String(s):
Threshold Count: 5
Threshold Count2: 5
Reaction Type: none
Entry Number: 127512
Tag: test_10.x.x.x
Verify Data: FALSE
Target Address:
Target Port: 0
Source Port: 0
LSR Path:
HTTP Operation: get
URL: http://10.x.x.x:80/OSPF-C.pdf
Proxy:
Raw String(s):
Threshold Count: 5
Threshold Count2: 5
Reaction Type: none
Entry Number: 136790
Tag: test_10.x.x.x
Verify Data: FALSE
Target Address:
Target Port: 0
Source Port: 0
LSR Path:
HTTP Operation: get
URL: http://10.x.x.x:80/OSPF-F.pdf
Proxy:
Raw String(s):
Threshold Count: 5
Threshold Count2: 5
Reaction Type: none
Entry Number: 186572
Tag: test_10.x.x.x
Verify Data: FALSE
Target Address:
Target Port: 0
Source Port: 0
LSR Path:
HTTP Operation: get
URL: http://10.x.x.x:80/OSPF-G.pdf
Proxy:
Raw String(s):
Threshold Count: 5
Threshold Count2: 5
Reaction Type: none
Entry Number: 203012
Tag: test_10.x.x.x
Verify Data: FALSE
Target Address:
Target Port: 0
Source Port: 0
LSR Path:
HTTP Operation: get
URL: http://10.x.x.x:80/OSPF-B.pdf
Proxy:
Raw String(s):
Threshold Count: 5
Threshold Count2: 5
Reaction Type: none
Entry Number: 203351
Tag: test_10.x.x.x
Verify Data: FALSE
Target Address:
Target Port: 0
Source Port: 0
LSR Path:
HTTP Operation: get
URL: http://10.x.x.x:80/OSPF-D.pdf
Proxy:
Raw String(s):
Threshold Count: 5
Threshold Count2: 5
Reaction Type: none
07-16-2010 08:30 AM
Post the output of "show rtr coll". If you click the Monitor button under Collector Mgmt do you see any graphs? The reports and Graph button will take
much more time to populate with data. The Monitor button will allow you to monitor your collector in real time.
07-16-2010 09:06 AM
Hi Joseph,
The monitor button displayed an empty graph, and i keep the window open for 30 mins or so but no tracking info.
I actually looked at the "sh rtr coll" command earlier and noticed that the collectors where going over the configured threshold (I left them on the default values). TestA seems to be ok on the default values. Although the others all showed that they were over the thresehold...so I reconfigured the threseholds for TestB operation and this seemed to work (in that I don't see any Overthresholds clocking up)...
Default for A,C,D,E,F,G
Timeout Value(msecs): 5000
Threshold(msecs): 5000
Sample Interval(secs): 300
Setting for B
Miscellaneous Settings
Threshold(msecs): 7000
heres the output of "sh rtr coll" after changing TestB operation. I guess the thresehold needs to be higher?
Entry Number: 19573
HTTP URL: http://10.x.x.x:80/OSPF-H.pdf
Start Time: 15:32:45.000 BST Fri Jul 16 2010
Comps: 12 RTTMin: 13380
OvrTh: 12 RTTMax: 15300
DNSTimeOut: 0 RTTSum: 167000
TCPTimeOut: 0 RTTSum2: 2326483870
TraTimeOut: 0 DNSRTT: 0
DNSError: 0 TCPConRTT: 105
HTTPError: 0 TransRTT: 166895
IntError: 0 MesgSize: 8255556
Busies: 0
Entry Number: 19573
Start Time: 16:32:45.000 BST Fri Jul 16 2010
Comps: 1 RTTMin: 13418
OvrTh: 1 RTTMax: 13418
DNSTimeOut: 0 RTTSum: 13418
TCPTimeOut: 0 RTTSum2: 180042724
DNSError: 0 TCPConRTT: 8
HTTPError: 0 TransRTT: 13410
IntError: 0 MesgSize: 687963
Busies: 0
Entry Number: 38060
HTTP URL: http://10.x.x.x:80/OSPF-A.pdf
Comps: 12 RTTMin: 545
OvrTh: 0 RTTMax: 1181
DNSTimeOut: 0 RTTSum: 10790
TCPTimeOut: 0 RTTSum2: 10211200
DNSError: 0 TCPConRTT: 107
HTTPError: 0 TransRTT: 10683
IntError: 0 MesgSize: 140424
Busies: 0
Entry Number: 38060
Comps: 1 RTTMin: 724
OvrTh: 0 RTTMax: 724
DNSTimeOut: 0 RTTSum: 724
TCPTimeOut: 0 RTTSum2: 524176
HTTPError: 0 TransRTT: 716
IntError: 0 MesgSize: 11702
Busies: 0
HTTP URL: http://10.x.x.x:80/OSPF-E.pdf
Comps: 12 RTTMin: 10386
OvrTh: 12 RTTMax: 11462
DNSTimeOut: 0 RTTSum: 129836
TCPTimeOut: 0 RTTSum2: 1405749174
DNSError: 0 TCPConRTT: 106
HTTPError: 0 TransRTT: 129730
IntError: 0 MesgSize: 4785024
Busies: 0
Comps: 1 RTTMin: 10391
OvrTh: 1 RTTMax: 10391
DNSTimeOut: 0 RTTSum: 10391
TCPTimeOut: 0 RTTSum2: 107972881
HTTPError: 0 TransRTT: 10383
IntError: 0 MesgSize: 398752
Busies: 0
HTTP URL: http://10.x.x.x:80/OSPF-C.pdf
Comps: 12 RTTMin: 8366
OvrTh: 12 RTTMax: 8715
DNSTimeOut: 0 RTTSum: 102440
TCPTimeOut: 0 RTTSum2: 874604482
HTTPError: 0 TransRTT: 102335
IntError: 0 MesgSize: 3308772
Busies: 0
Comps: 1 RTTMin: 8156
OvrTh: 1 RTTMax: 8156
DNSTimeOut: 0 RTTSum: 8156
TCPTimeOut: 0 RTTSum2: 66520336
HTTPError: 0 TransRTT: 8148
IntError: 0 MesgSize: 275731
Busies: 0
HTTP URL: http://10.x.x.x:80/OSPF-F.pdf
Start Time: 15:32:46.000 BST Fri Jul 16 2010
Comps: 12 RTTMin: 13358
OvrTh: 12 RTTMax: 15263
DNSTimeOut: 0 RTTSum: 166206
TCPTimeOut: 0 RTTSum2: 2304442542
DNSError: 0 TCPConRTT: 103
HTTPError: 0 TransRTT: 166103
IntError: 0 MesgSize: 8267256
Busies: 0
Start Time: 16:32:46.000 BST Fri Jul 16 2010
Comps: 1 RTTMin: 13273
OvrTh: 1 RTTMax: 13273
DNSTimeOut: 0 RTTSum: 13273
TCPTimeOut: 0 RTTSum2: 176172529
HTTPError: 0 TransRTT: 13265
IntError: 0 MesgSize: 688938
Busies: 0
HTTP URL: http://10.x.x.x:80/OSPF-G.pdf
Comps: 12 RTTMin: 4769
OvrTh: 11 RTTMax: 5883
DNSTimeOut: 0 RTTSum: 65594
TCPTimeOut: 0 RTTSum2: 359900562
HTTPError: 0 TransRTT: 65491
IntError: 0 MesgSize: 1856172
Busies: 0
Comps: 1 RTTMin: 4725
OvrTh: 0 RTTMax: 4725
DNSTimeOut: 0 RTTSum: 4725
TCPTimeOut: 0 RTTSum2: 22325625
DNSError: 0 TCPConRTT: 9
HTTPError: 0 TransRTT: 4716
IntError: 0 MesgSize: 154681
Busies: 0
HTTP URL: http://10.x.x.x:80/OSPF-B.pdf
Start Time: 16:20:30.000 BST Fri Jul 16 2010
Comps: 3 RTTMin: 1121
OvrTh: 0 RTTMax: 1751
DNSTimeOut: 0 RTTSum: 4020
TCPTimeOut: 0 RTTSum2: 5640546
DNSError: 0 TCPConRTT: 31
HTTPError: 0 TransRTT: 3989
IntError: 0 MesgSize: 334260
Busies: 0
HTTP URL: http://10.x.x.x:80/OSPF-D.pdf
Comps: 12 RTTMin: 10229
OvrTh: 12 RTTMax: 11345
DNSTimeOut: 0 RTTSum: 127819
TCPTimeOut: 0 RTTSum2: 1362276531
HTTPError: 0 TransRTT: 127713
IntError: 0 MesgSize: 4578072
Busies: 0
Comps: 1 RTTMin: 10012
OvrTh: 1 RTTMax: 10012
DNSTimeOut: 0 RTTSum: 10012
TCPTimeOut: 0 RTTSum2: 100240144
HTTPError: 0 TransRTT: 10004
IntError: 0 MesgSize: 381506
Busies: 0
07-16-2010 10:02 AM
07-19-2010 03:29 AM
Hi Joseph,
This morning I changed the thresholds for all of the operations and I can now see data in the monitor graph for all of them. Thanks for helping there. My main issue though is still with generating reports.
After verifying that all the collectors are displaying realtime graphs I left it running for over an hour and tried to generate an hourly report. The report only had data for testA (which was working anyway)....it had no report data held for the remaining 7 collectors. I've attached a screenshot of the report.
Perhaps i should delete the collectors, recreate them and leave it running for awhile and try again. Actually I'll try that now....
cheers
Steven
07-19-2010 07:25 AM
I tried recreating the collectors and used a different router and appears to be the same issue. Test A gives results - other collectors don't. I guess i possibly need to revise the thresholds configured on the http operations created. I'm not sure i fully understand why though because the threshold on the old IPM are the same and work fine. I'll now toggle the threseholds and see if i can get the reports to pull data for the other collectors.
08-02-2010 06:25 AM
It seems that the reporting issue is seperate from the issue i was having with collectors. I can now see collectors and monitor stats but reports won't pull data for the majority of the collectors created.
