07-15-2010 05:07 AM - edited 02-21-2020 04:01 AM
There is a problem that is coming with the clients that sometimes on some of the clients Cisco NAC Agent login Splash screen is not displayed onto the screen for login for some of the newly added machines.Are there any special requirements for cisco Agent on the client machines.
waqas
Solved! Go to Solution.
07-15-2010 06:22 AM
Waqas,
No particular requirements, except that they be on the supported OS list. For example server OSs are not supported so if you were trying to install/run on a 2003 or 2008 server, that won't work.
HTH,
Faisal
07-15-2010 06:22 AM
Waqas,
HTH,
Faisal
07-15-2010 10:55 PM
Dear Faisal ,
My agent do support that XP OS as some of the users are getting the splash screen on the same OS. Maybe some other agent requirement like JRE version e.t.c
Waqas
