07-15-2010 05:42 AM - edited 03-06-2019 12:02 PM
Hi ,
On a 4507R Sup 4 redundant, IOS version 12.2-44.SG
I have an WS-X4548-GB-RJ45 in slot 7.
On this card are connected Servers (and Vmware) in access mode L2.
On all interface slot 7 who is in up/up state the output drops counters increase in gust. why ?
What means the output drops ?
In slot 3 and 4 I have the other switch attachement in trunk mode L2, there is no output drops counter problem.
But I see that on slot 5 and 6 I have WS-X4232-GB-RJ and WS-X4148-RJ card, with other server who has the counter output drops increase, but only on some interface.
In general the users complain about deceleration network.
I test to remove the flow control on a server cluster interface on switch side and server side but the problem persist.
Any idea ? Which can be the problem ?
Show mod:
Chassis Type : WS-C4507R
Power consumed by backplane : 40 Watts
Mod Ports Card Type Model
1 2 Supervisor IV 1000BaseX (GBIC) WS-X4515
2 2 Supervisor IV 1000BaseX (GBIC) WS-X4515
3 18 1000BaseX (GBIC) WS-X4418-GB
4 6 1000BaseX (GBIC) WS-X4306-GB
5 34 10/100BaseTX (RJ45), 1000BaseX (GBIC) WS-X4232-GB-RJ
6 48 10/100BaseTX (RJ45) WS-X4148-RJ
7 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45
Example on interface G7/3, counter clear 1 hour 36 minutes:
GigabitEthernet7/3 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet Port, address is 0021.d894.d1d2 (bia 0021.d894.d1
d2)
Description: VMWARE5A.AT1
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
input flow-control is on, output flow-control is on
Last input never, output never, output hang never
Last clearing of "show interface" counters 01:36:32
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 17163
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 338000 bits/sec, 175 packets/sec
5 minute output rate 758000 bits/sec, 256 packets/sec
1056176 packets input, 256376196 bytes, 0 no buffer
Received 11824 broadcasts (11572 multicasts)
1693482 packets output, 683221392 bytes, 0 underruns
0 lost carrier, 0 no carrier
Thank you by advance
Hervé
07-15-2010 11:42 PM
Hi ,
Show mod:
7 48 10/100/1000BaseT (RJ45) WS-X4548-GB-RJ45Example on interface G7/3, counter clear 1 hour 36 minutes:
d2)
0 output buffer failures, 0 output buffers swapped outThank you by advance
Hervé
Hi Herve,
As per the interface logs output drops is more genrally output drops appear whenever system is attempting to hand off a packet to the transmit buffer but no buffers are available. This can happen due to improper queuing done. You can increse output hold queue ( hold-queu out ) interface config command to increae the queue size.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
