3750 negative values on counters
rwilletts
Using the output ' sh sw stack-ring activity detail ' we can see negative values - can anyone explain this behaviour ?
Switch   Asic  Rx Queue-1  Rx Queue-2  Rx Queue-3  Rx Queue-4       Total
1           0          12           0   520198195           0   520198207
1          16           0  1871524325           0  1871524341
1           2          12           0           0           0          12
1           3          16           0          91           0         107
1           4   352083225    73592804  1473849268           0  1899525297
1           5          12           0           0           0          12
1           6          16           0           0           0          16
                                              Switch 1 Total: -   3719304
2           0          12           0 - 881522564           0 - 881522552
2           1          16           0  1059105591           0  1059105607
2           2          12           0        1644           0        1656
2           3          16           0       96300           0       96316
2           4   360337389    47107309  1825173257           0 -2062349341
2           5          12           0           0           0          12
2           6          16           0           0           0          16
                                              Switch 2 Total: -1884668286
Total frames sent to stack ring : -1888387590
Viral Bhutta
In terms of the negative value, it is a cosmetic issue and does not indicate packet loss. It is possible that as the counter reaches its maximum value, it wraps to a negative number.
Reboot of the switch should clear this problem.
There have been some cases in the older version of the code and have not seen after 12.2(35)SE
That's interesting as the code is 12.2(25),  have you seen a bug listed for this issue ?
Unfortunately I dont have a bug id for this.
This is a corner case with very few users ever seeing it,
and by the time it was found newer code was already out where this was not reproducible.
Let me know if this helps.
