Cisco WLC Web authentication issue
I have setup a WLC 2112 exactly as  per the different deployment guides, still I am failing to get the  certificate when using web authentication for my guest VLAN. I then also  do not get diverted to the internal web page to login in with one of  the local net users.
Also if I manually enter: https://1.1.1.1/login.html,  the page is not found, however if I browse the Dynamic guest interface  on say: http://20.20.20.10 I get the header  in the web page that says "web authentication redirect" but then nothing  happens.
Is it possible to use only one WLC 2112 with local  net user database and perform web authentication for guests via their  own dynamic interface? I do not have a second WLC to perform mobility  anchoring. Please any help would be appreciated.
mirizarr Fri, 07/16/2010 - 05:56
  • Cisco Employee,
Joe,
  If you only have on controller, you don't need to anchor the WLAN/SSID.  When you do the https://1.1.1.1/login.html, do you get an security error message or you get page canno't be display?  Are you using the internal web page on the controller?
Manuel
mirizarr Fri, 07/16/2010 - 07:36
  • Cisco Employee,
Joe,
   Usually, you will get a security error.  Not getting anything indicate something else is the problem.   I will suggest that you open a TAC service request so a TAC engineer can look at the config, and the debugs.
Manuel
pavol.jasurek Wed, 09/25/2013 - 02:39
Hello, I also installed Guest access, the issue is, that I need to  have https access for WLC administration, but I`d like to have only http  for the web login page, so users won`t get the certificate error. It is  any possibility, how to set this up? Under Management -> HTTP-HTTPS  menu, there is also an option "WebAuth SecureWeb". When I disable it,  users reports, they don`t get any web page so they can`t confirm and  Guest wireless doesn`t work .... Any advice how to solve it without signed certificate?
Thank you.
Pavol Jasurek
Scott Fella Wed, 09/25/2013 - 04:31
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
If your on v7.2 or newer, there is a feature just to disable http for the webauth only.
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_tech_note09186a...
