Cisco 6500 - Making a switch port invisible
Jul 15th, 2010
I have a customer that insists we are either blocking STP BPDU traffic, and in wireshark traces our switches are mixing BPDU traffic with theirs.  My goal is to configure a transparent switch port that allows everything, customer can send anything end-to-end thus making our switch invisible.  Also, I wish to constrain this to there port only.
Network:
Two Cisco 6500 switches running IOS
Customer:
Using port Fa6/7 on Cisco6500-LOCA to port Fa6/7 on Cisco6500-LOCZ
Question;
Will the configuration below work?  Has anybody done this?  My reference is http://packetlife.net/blog/2010/apr/15/invisible-catalyst-switch/
Configuration:
On Cisco6500-LOCA
interface fa6/7
description Facing LOCA
switchport mode dot1q-tunnel
switchport access vlan 201
speed 100
duplex full
mtu 9216
no cdp enable
switchport nonegotiate
no keepalive
l2protocol-tunnel cdp
l2protocol-tunnel stp
l2protocol-tunnel vtp
l2protocol-tunnel point-to-point pagp
l2protocol-tunnel point-to-point lacp
l2protocol-tunnel point-to-point udld
end
interface gig 1/1
description Trunk between Cisco6500-LOCA and Cisco6500-LOCZ
switchport mode trunk
switchport trunk allowed vlan 201,800-850
mtu 9216
end
On Cisco6500-LOCZ
interface fa6/7
description Facing LOCZ
speed 100
duplex full
mtu 9216
no cdp enable
no keepalive
end
interface gig 1/1
description Trunk between Cisco6500-LOCZ and Cisco6500-LOCA
mtu 9216
end
-Mn
Jayakrishna Mada Fri, 07/30/2010 - 01:15
  • Cisco Employee,
Mn,
Yes that should work.
I am assuming that 6/7 is the end points going to your customer. Also make sure that your have "dot1q tag native".
Jayakrishna
Hitesh Vinzoda Fri, 07/30/2010 - 03:31
  • Silver, 250 points or more
Add under interfaces
vlan dot1q tag native
and in global configuration add :
errdisable recovery cause l2ptguard
Hitesh Vinzoda
Pls rate useful posts
