Call Connecting in Q931 but not ringing
Jul 15th, 2010
  • Silver, 250 points or more
I have a Voice GW - h323, If I do a Q931 debug I can see the "call" connect as below
DB1
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA18388
                Preferred, Channel 8
        Calling Party Number i = 0x0081, '8xxx'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '7xxxx'
Jul 15 17:44:32.776 CET: %ISDN-6-CONNECT: Interface Serial0/0/0:7 is now connected to 8xxx N/A
Jul 15 17:44:32.780 CET: %ISDN-6-CONNECT: Interface Serial0/0/0:7 is now connected to 8xxx N/A
Jul 15 17:44:32.780 CET: ISDN Se0/0/0:15 Q931: TX -> CALL_PROC pd = 8  callref = 0x9DB1
        Channel ID i = 0xA98388
                Exclusive, Channel 8
But the phone does not ring. I was going to add the progress_enable settings but is there any thing else I can look for, confirm.
progress_ind alert enable 8
progress_ind progress enable 8
progress_ind connect enable 8
If I do a csim start xxxx should the  destination phone should ring ?
The connectoin is =
CUCM 1>>>>>>GW1a >>>>>>GW1b>>>>>NETWORK>>>>>GW2a>>>>>>GW2b>>>>>CUCM2
The connection is H323, if I point GW1b to another GW3b which connects to a PABX it works ok but not the above
any ideas
thanks
