IPICS. VTG delay
Jul 15th, 2010
Hi all,
I writing this post because I'm doing an IPICS 2.01instalation right now. I put 4 channels, one with a nextel and 3 with motorola radio bases.
I have great comunication between the PMC and IP phones to all the channels, but when I enable a VTG on all the 3 motorolas I get a delay in the comunication, like 3 seconds. I'm not sure why this is happening, do anyone know how can I reduse this delay? do I need to change anything in the config?
I have attached my RMS configuration. I thank you all in advance for all your time and help.
Ramón
engineerangelo Wed, 06/29/2011 - 01:50
I'm also having the same problem with my radios. I have 2 brands of radios, a Motorola and a Kenwood. If I use the Motorola, It would take like 1.5 seconds for the LED light of the Kenwood E&M port to light up. It means I have to wait for 1.5 secs before my voice can be heard on the other side. And if I use the Kenwood, I need to speak loud and in a continuous manner before it can be heard on the other side. I have the same config on both voice ports. If I exchange the connection, it's still the same.
voice-port 0/0/0
voice-class permanent 1
auto-cut-through
operation 4-wire
type 3
signal lmr
lmr e-lead voice
lmr duplex half
lmr led-on
input gain auto-control
output attenuation auto-control
no comfort-noise
timeouts call-disconnect 3
connection trunk 1001
voice-port 0/1/0
auto-cut-through
operation 4-wire
type 3
signal lmr
lmr e-lead voice
lmr duplex half
lmr led-on
no comfort-noise
connection trunk 1002
I've also tried on changing the parameters. But it seems the same.
Thanks in advance.
John Gillich Wed, 06/29/2011 - 06:20
Try this config for a Motorola XLT Radio.
The XTS are portables, all models 2500, 3000, 5000 etc. should all behave the same.
The XTL is the mobile.
Motorola XTL series portables.  It should also work with XTS series.  Are you also using a REM3601 & REM4475 cables from http://www.networkedradio.com ?
You will have to adjust input gain & output attenuation for best audio once its working.
voice-port
auto-cut-through
operation 4-wire
type 3
signal lmr
bootup e-lead off
lmr e-lead voice
lmr m-lead inactive
lmr duplex half
lmr led-on
input gain 16
output attenuation 17
no echo-cancel enable
no comfort-noise
timeouts wait-release 3
timing hookflash-in 10
timing hangover 40
timing delay-voice tdm 250
connection trunk 101
description VAD Controlled Radio Example
threshold noise -40
dial-peer voice 101 voip
destination-pattern 101
rtp payload-type lmr-tone 107
rtp payload-type nte-tone 108
session protocol multicast
session target ipv4:239.192.0.1:21000
dtmf-relay rtp-nte
codec g711ulaw
ip qos dscp cs5 media
vad aggressive
John Gillich Wed, 06/29/2011 - 06:24
Below is another example.
The XTS5000 operates in VOX/VAD mode as it does not have a COR lead.  Most of the time there is no need to do programming to the handset.  Simply attached the XTS5000 cable from www.networkedradio.com (REM3601 + REM4475) to the radio, use an in-line 20dB attenuator (REM-621), and then attach to the router’s E&M port.
This configuration was used for both conventional and trunked systems.  It seemed to work well as a middle of the road configuration.  The areas of the configuration you will need to consider for these various types of systems will generally be timing delay-voice tdm and timing hangover.
You will also want to be careful to consider if these resource will need to be cross-patched with other resources.  The configuration I sent was designed for this capability in mind.  However, this configuration prevents status tones such as binks and bonks from being heard from the IPICS user as the ports are set to half-duplex.  A longer discussion will ensue if you need status tones to be heard.
LMR Router Example config:
voice class permanent 1
  signal timing oos restart 50000
  signal timing oos timeout disabled
  signal keepalive disabled
  signal sequence oos no-action
interface Vif1
  ip address XXXXX 255.255.255.252
  ip pim sparse-mode
voice-port XXX
  auto-cut-through
  operation 4-wire
  type 3
  signal lmr
  bootup e-lead off
  lmr e-lead voice
  lmr led-on
  output attenuation 9
  no comfort-noise
  timing hangover 100
  connection trunk 79990001
  description *********** PD TACTICAL #1
  music-threshold -15
  threshold noise -40
voice-port XXX
  auto-cut-through
  operation 4-wire
  type 3
  signal lmr
  bootup e-lead off
  lmr e-lead voice
  lmr led-on
  no comfort-noise
  timing hangover 100
  connection trunk 79990002
  description *********** PD TACTICAL #2
  music-threshold -15
  threshold noise -40
dial-peer voice XXXXXX voip
  destination-pattern 79990001
  session target ipv4:XXXXXX:21000
  codec g711ulaw bytes 80
  vad aggressive
  destination-pattern 79990002
  vad aggressive
end
engineerangelo Wed, 06/29/2011 - 19:07
Hi John,
I'm using Motorola GP328 and Kenwood TK2107. I tried the your first example on the Motorola. If I speak on the Motorola, it takes about 1.5 to 2 secs before my voice is heard on the Kenwood radio.
John Gillich Thu, 06/30/2011 - 08:53
Try decreasing the delay timing delay-voice tdm 250 to a lower value on the radio voice ports. Make sure you do a shut no shut on the port after making the change.
engineerangelo Sun, 07/03/2011 - 18:05
Hi John,
I've already removed the timing delay-voice tdm command. By default, the delay is 0ms right? How about your setup, aren't you experiencing delays?
