Looking for procedure to restore a configuration to a wae.
Jul 15th, 2010
I am trying to restore the configuration to a WAE 7341.  copy tftp start does not seem to be the right command.  Is there another way to restore the configuration?
Zach Seils Fri, 07/16/2010 - 08:42
  • Cisco Employee,
Was the device previously registered with a Central Manager, or is it just a text copy of the CLI configuration that you are trying to restore?
Zach
DARYLE DIANIS Fri, 07/16/2010 - 08:53
The device was RMA'd, so I had it sitting on my desk and since the config was so small, it was just as easy to cut and paste it in from the command line.  I was suprised that copy tftp didn't seem to be the right way to upload the config, like a router or switch.  No problem, though, thanks for asking.
Zach Seils Mon, 07/19/2010 - 17:23
  • Cisco Employee,
What error did you get with the copy tftp startup-config command?
Zach
DARYLE DIANIS Tue, 07/20/2010 - 09:02
there was no error, the command completed ok.  when I rebooted, the wae did not find config that I uploaded.  When I called tac, they said I had to paste it in and it turned out to be easy to do.  Its ok now, but I really won't be able to try anything out, now that I'm back in production.
thanks,
