Custumized Banckground images for 7965, 7940 & 7912 In CUCME 7.x
vortiz_mnet
is possible to change background in those ip phones with Callmanager express 7.x? and how is that configuration?
thnks
Jaime Valencia
7965 yes
7940 no
7912 yes
https://supportforums.cisco.com/message/1088132#1088132
https://supportforums.cisco.com/message/351707#351707
You just need to search the community and you'll find info on this.
try searching CME + background
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
is it not possible to change the backgroud with cisco phone designer software. i changed in my organization's phones using same but now sure of the models which u mentioned...
