Command frame-relay traffic-shaping in router 7609 Version 12.2(33)SRC
griffith2009
I have router 7609  Version 12.2(33)SRC, but when i try to execute de command:
interface Serial3/0/0
i can´t execute.
This version don´t support that command?
Configuration:
mtu 1500
no ip address
encapsulation frame-relay IETF
logging event subif-link-status
logging event dlci-status-change
framing g751
dsu bandwidth 34010
dsu mode 1
no frame-relay inverse-arp
frame-relay lmi-type ansi
end
IOS Version:
Router1#sh ver
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRC, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Fri 11-Jan-08 16:04 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
Router1 uptime is 1 week, 4 days, 6 hours, 21 minutes
Uptime for this control processor is 1 week, 4 days, 6 hours, 19 minutes
System returned to ROM by reload (SP by reload)
System restarted at 09:54:42 VEN Sun Jul 4 2010
System image file is "disk0:c7600s72033-adventerprisek9-mz.122-33.SRC.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7609 (R7000) processor (revision 1.2) with 983008K/65536K bytes of memory.
Processor board ID FOX1003026X
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1 Enhanced FlexWAN controller (2 Serial).
4 Virtual Ethernet interfaces
100 Gigabit Ethernet interfaces
2 Serial interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Line Command:
Router1(config-if)#frame-relay ?
  accounting             Special accounting instruction
  address-reg            ELMI address registration
  broadcast-queue        Define a broadcast queue and transmit rate
  class                  Define a map class on the interface
  congestion-management  Enable Frame Relay congestion management
  de-group               Associate a DE group with a DLCI
  fast-restart           fast restart on switchover
  fragment               Enable end-to-end fragmentation for all PVCs
  ifmib-counter64        Support IF-MIB's total packet/byte counts of Counter64
                         on FR if/subif when main interface's ifSpeed < 20 Mbps
  interface-dlci         Define a DLCI on an interface/subinterface
  intf-type              Configure a FR DTE/DCE/NNI interface
  inverse-arp            Enable/disable FR inverse ARP
  ip                     Frame Relay Internet Protocol config commands
  lapf                   set LAPF parameter
  lmi-n391dte            set full status polling counter
  lmi-n392dce            LMI error threshold
  lmi-n392dte            LMI error threshold
  lmi-n393dce            set LMI monitored event count
  lmi-n393dte            set LMI monitored event count
  lmi-t392dce            set DCE polling verification timer
  lmi-type               Use CISCO-ANSI-CCITT type LMI
  local-dlci             Set source DLCI when LMI is not supported
  map                    Map a protocol address to a DLCI address
  multicast-dlci         Set DLCI of a multicast group
  policing               Enable Frame Relay policing
  priority-dlci-group    Define a priority group of DLCIs
  qos-autosense          enable QOS autosense
  svc                    Enable frame relay SVCs
  traps-maximum          set max traps FR generates at link up or when getting
                         LMI Full Status message
  vc-bundle              configure a frame-relay vc-bundle
Reza Sharifi
It is not supported on flex WAN modules:
Unsupported features
Frame Relay traffic shaping (FRTS), ISDN, Frame Relay switching, Layer 2 Tunneling Protocol (L2TP), Layer 2 Forwarding (L2F), Point-to-Point Tunneling Protocol (PPTP)
Have a look at this doc for more info:
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_data_sheet09186a00801df1d9.html
Reza
