CM showing wrong OS code
Jul 15th, 2010
Hi all,
We installed new WAE into the network with 4.1.5f code, but when i look from the central manager it is showing 4.1.5c.,, wierd,, the whole setup is working on 4.1.5f.. any reasons ,, or possible solution.
Dhana
smnambia Thu, 07/15/2010 - 15:42
Hi Dhana,
Did you refresh the CM gui screen and is it still showing up as 4.1.5c? Is the CM running WAAS 4.1.5f?
Could you send me the CM screenshot showing the wrong software ,along with sh ver and sh cms info output from the device cli.
-Smita
Cisco PDI HelpDesk
http://www.cisco.com/go/pdihelpdesk
dhanasekaran.r Thu, 07/15/2010 - 16:10
I have attached screenshot of CM. The CM is running on the OS 4.1.5f. The WAE is implemented with OS 4.1.5f.
xxwa1#sh ver
Cisco Wide Area Application Services Software (WAAS)
Copyright (c) 1999-2010 by Cisco Systems, Inc.
Cisco Wide Area Application Services Software Release 4.1.5f (build b2 Apr 20 2010)
Version: oe574-4.1.5f.2
Compiled 12:26:34 Apr 20 2010 by cnbuild
System was restarted on Mon Jul 12 12:22:50 2010.
The system has been up for 3 days, 5 hours, 45 minutes, 59 seconds.
xxwa1#sh cms info
Device registration information :
Device Id                            = 7564128
Device registered as                 = WAAS Application Engine
Current WAAS Central Manager         = 165.28.96.242
Registered with WAAS Central Manager = 165.28.96.242
Status                               = Online
Time of last config-sync             = Thu Jul 15 18:05:36 2010
CMS services information :
Service cms_ce is running
smnambia Thu, 07/15/2010 - 16:22
Thanks Dhana
As per the CM screenshot I see that wae devices brcpwa1,breswa1 and brmawa1 are showing up as 4.1.5c
As per the wae device cli output looks like the wae hostname is xxwa1 and I don't see this one on the CM screenshot?
Is the xxwa1 wae device also showing up as 4.1.5c for sware on the CM gui? The xxwa1 should show up under the Device Name(Mange Devices) on the CM gui
As per cms info the device last synced with CM today at 18:05:36
-Smita
Cisco PDI Helpdesk
dhanasekaran.r Thu, 07/15/2010 - 16:54
Hi Smita,
The xxwa1 is the brmawa1.
brmawa1#sh ver
brmawa1#sh cms info
Device Id                            = 7564128
Status                               = Online
brmawa1#
dhanasekaran.r Wed, 08/11/2010 - 08:01
Hi Smita,
Thanks, The issue was resolved after the WAE was upgraded with OS again. The issue was due to improper loading of OS code from rescue CD.
