RVL200 Port Forwarding to Multiple Subnets
Jul 15th, 2010
I just updated an RVL200 to for the sole purspose of utilizing this new feature (I've been waiting for this to happen) and when I've tried to enable a port range with a subnet assigned to a VLAN other than the default VLAN ID 1, I get a warning popup that the address is not an available range found in any of the multiple subnets, VLANS, etc. when the subnet is clearly being used and working.  I can assign forwarding to the range on VLAN 1 with out any problem.
What can I do to make this work?  I'll be very sad if it means clearing out the configuration and starting from scratch.  Please help.
Te-Kai Liu Tue, 07/20/2010 - 12:18
As far as I know, there is no known issue with the Port Forwarding function of RVL200 firmware If you are still experiencing the problem, please contact the Small Business Support Center and provide your RVL200 config file so we can do more detailed analysis of the issue.
Related Content
