Move CUPS to new Cluster
Answered Question
Jul 16th, 2010
  • Silver, 250 points or more
I have CUPS 7 assicated to a test cluster 7.x , can I and how much
effect is involved to re-point it to another Cluster running 6.1.2 or do I need to re-install it again
thanks
Correct Answer by htluo about 6 years 10 months ago
Double check compatibility guide.  If CUPS 7 is compatible with CUCM 6.1.2, it should be ok to switch cluster.
Michael
http://htluo.blogspot.com
Overall Rating: 5 (1 ratings)
Correct Answer
htluo Fri, 07/16/2010 - 05:45
  • Red, 2250 points or more
Michael
iptuser55 Fri, 07/16/2010 - 08:44
Thanks, I went through the CUCM page on CUPS but it seems the customer does not know the Security Password which is stopping me moving from  one cluster to another
