Outbound Reporting Database feilds
Jul 16th, 2010
Dear All
I am working on OB dialer and installed both Transfer to IVR and Agent Based Campaign. I have a few questions regarding reporting for OB.
  1. Is there anyway in which we can find the call treatment an dialed number got using webview?
  2. In SQLs Outbound DB what does these feilds mean?
    1. call status zone1
    2. Call Result
If some one could point me towards a documentaion that explains point 2 that would be highly appreciated.
Hassan
Muhammad Amir Raza Fri, 07/16/2010 - 04:45
(not possible using default Webview templates, only way you need to develop customize template (Infomaker)and load in Webview)
2. In SQLs Outbound DB what does these feilds mean?1. call status zone1 2. Call Result
(I am not sure, but I think zone's represents timezones)
For detail DB just download icm DB schema handbook.
Muhammad Amir Raza
hassanalirazi Fri, 07/16/2010 - 04:52
Thank you for your response. Can you please post the exact link where i can download the DB Schema handbook.
Hassan Ali
khambetea Fri, 07/16/2010 - 13:39
Webview does not provide with call details hence you will need to do queries against the database. If you query the HDS DB against the Dialer_Detail table, you will get the details you are looking for.
For example - select Phone, CallResult, DateTime from
Dialer_Detail
where DateTime > '06/03/2010'
