UCCX 7.0 HA SQL License
Jul 16th, 2010
Experts,
Can you help me in knowing how many SQL2000 licences one need to order for UCCX7.0 HA pair. I understand that both servers require SQL2000 install, but do need two separate SQL Licences as well? or One licence is required i.e. on active server.
Many Thanks, JBS
Mohammad Hasan ... Mon, 07/19/2010 - 13:06
Hello JBS,
You don't have to buy SQL license separately from Cisco.When you order UCCX with HA ,Cisco ships the modified version of SQL compatible with HA model. If you use normal windows SQL then HA will not wok and you will get an error " installed SQL is not a Cisco Authorized one" I don't remember the exact error though.
Also while installing SQL ,in the License section you have to choose based number of possessor  in the UCCX server.
Hope this helps...
Hasan Jafri
