NSS324 - Firmware BIN File
Jul 16th, 2010
G'day Guys,
I took a NSS324 home for testing purposes and I think I busted it.
Where can I get a copy of the firmware BIN file to restore the unit.
Cheers Ant
David Hornstein Tue, 07/20/2010 - 19:42
Hi Purchasing Multimedia,
Glenn is correct the SBSC is the place to go,  the technician there should have escalated the case to his/her next level of support or diagnosed the problem and then escalated the case.
Please take the effort to call the Small Business support Center back again, and open a case or re-open the old case number and this time ask the technician to escalate the case if they can't get you the software.
If you run into any issue, as a Systems Engineer at cisco I am happy to facilitate the necessary support you require.
If you need my assistance send your open case number to me with your contact details.
My email address is [email protected]
regards Dave
