VPN Remote Access CRLs
Jul 16th, 2010
Suppose I configure IPSec VPN with certificate authentication for Cisco VPN client (during IKE phase 1),
Cisco ASA is also configured with certificates from the same CA server and I am able to download CRL.
IPSec VPN is functional.
Later, I revoke VPN client certificate from CA server and I download CRL to Cisco ASA again. VPN client is still able to connect to Cisco ASA.
What am I doing wrong?
sjbdallas Fri, 07/16/2010 - 08:29
Did you check through the CA Certificate options under Certificate Management in the ASDM?  There are settings there related to checking for certiticate revocation and there's a checkbox to "Consider certficate valid if revocation information cannot be retrieved".  When I first set up my CA, that was on by default.
NemanjaPoprzen Sat, 07/17/2010 - 02:12
Option "Consider certficate valid if revocation information cannot be retrieved" is not selected. Restart of CA server solved the problem, :-D.
Thank you
