Upgrading from Ciscoworks 2.6 to 3.2 Database error
Jul 16th, 2010
I am upgrading from Ciscoworks 2.6 to 3.2. When i run the eval.exe file, it runs to a point where it attempts to backup the current version. After about 10GB, it gets a cfm fail and tells me to look in the backup log. .In the log, there is a fatal error message saying
ERROR(1055): Fatal error: Database engine 'dfmFhEng' could not be started on database 'dfmFhDb' in Bulk mode
Has anyone seen this before?
Attached are the install log and the backup log
Derek
Joe Clarke Fri, 07/16/2010 - 08:41
It could be that the DFM Fault History database ic corrupt.  Check this document on database troubleshooting for more details:
https://supportforums.cisco.com/docs/DOC-8796
You may either need to reinitialize the database transaction log, or the database itself.  Then you can try the upgrade again.
Derek McCormick Tue, 07/20/2010 - 01:48
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
The info you provided was very helpful. I had to reinitialize the dfmEPM, dfmINV and the dfmFh databases.
I am still not out of the woods however, when I run a self test I get the following:
Server Info
generated Mon Jul 19 18:40:18 2010
Table of Contents
PASS
backup.pl
FAIL
database.pl
PASS
mem.exe
PASS
network.pl
PASS
odbc.pl
PASS
platform.pl
PASS
snmp.pl
backup.pl
PASS    the backup script is installed
go to top
database.pl
FAIL    Self Test Fail to query cmf.DbVersion, Error: Database server not found (DBD: login failed)
        Self Test Fail to query cmf.SYSTABLE, Error: Database server not found (DBD: login failed)
go to top
mem.exe
PASS    2146902016 bytes of physical ram and 3600957440 bytes total page file size
go to top
network.pl
PASS    lookup of loopback address succeeded
go to top
odbc.pl
PASS    Recommended DLL versions found.
go to top
platform.pl
PASS    supported platform : 'ServerNT'
go to top
snmp.pl
PASS    CWSNMP.DLL and cwwsnmp32.dll found in correct place
go to top
When I attempt to go into the device manager I get, if I try and do a device discovery I also get the same message. I have checked the processes. I originally tried to start the DCR server manually, but now it reports as being up since today.  Are there any log files I should look at? I attempted to run a system report  and it reports – no records. I get the following error:
{CmfDbMonitor}: Cannot connect to cmf database, please contact your systems administrator
Any help appreciated.
Cheers,
Derek
Joe Clarke Tue, 07/20/2010 - 11:26
It looks like the LMS 3.2 upgrade may have failed.  Post the output of the pdshow command.
Systems Integration Wed, 07/21/2010 - 01:40
D:\Program Files\CSCOpx\bin>pdshow
ERROR: connect to dmgtd process on "127.0.0.1" on port 42340 failed:
Derek McCormick Wed, 07/21/2010 - 03:00
Here you go
D:\Program Files\CSCOpx>pdshow | more
        Process= UPMDbEngine
        State  = Program started - No mgt msgs received
        Pid    = 304
        RC     = 0
        Signo  = 0
        Start  = 7/21/2010 9:38:51 AM
        Stop   = Not applicable
        Core   = Not applicable
        Info   = Application started by administrator request.
        Process= UPMDbMonitor
        State  = Running normally
        Pid    = 6408
        RC     = 0
        Signo  = 0
        Start  = 7/21/2010 9:38:55 AM
        Info   = DbMonitor Running Normally.
        Process= Tomcat
        Pid    = 8352
        RC     = 0
        Signo  = 0
        Start  = 7/21/2010 9:38:59 AM
        Process= TomcatMonitor
        Pid    = 12796
        RC     = 0
        Signo  = 0
        Start  = 7/21/2010 9:51:59 AM
        Info   = Tomcat Server up
        Process= Apache
        Pid    = 5316
        RC     = 0
        Signo  = 0
        Start  = 7/21/2010 9:52:32 AM
        Process= RMEDbEngine
        Pid    = 1012
        RC     = 0
        Signo  = 0
        Start  = 7/21/2010 9:46:14 AM
Process= Proxy
Pid    = 5424
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:46:18 AM
Info   = Server started by admin request
Process= ProcSysBus
Pid    = 7504
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:46:23 AM
Process= OpsxmlDbEngine
Pid    = 10968
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:46:31 AM
Process= OpsXMLRuntime
Pid    = 11316
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:46:38 AM
Process= CWAPublisher
Pid    = 7924
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:46:42 AM
Process= NameServer
Pid    = 11972
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:46:46 AM
Info   = Auto Generated Reply
Process= EDS
Pid    = 1352
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:46:50 AM
Info   = Initialization complete
Process= LicenseServer
Pid    = 9324
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:46:58 AM
Process= IpmDbEngine
Pid    = 10712
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:47:03 AM
Process= INVDbEngine
Pid    = 3972
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:47:12 AM
Process= FHPurgeTask
State  = Never started
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Info   = Not applicable,
Process= FHDbEngine
Pid    = 8312
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:47:18 AM
Process= ESS
Pid    = 9020
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:47:22 AM
Process= EssMonitor
Pid    = 7176
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:47:26 AM
Info   = ESS is fully up now !
Process= EventFramework
Pid    = 6612
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:48:02 AM
Process= PMServer
Pid    = 8384
RC     = 0
Signo  = 0
Info   = PMServer is up and running
Process= SyslogCollector
Pid    = 1300
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:48:06 AM
Process= EPMDbEngine
Pid    = 9952
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:48:10 AM
Process= EPMServer
Pid    = 8200
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:48:15 AM
Process= FHServer
Pid    = 12720
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:48:19 AM
Info   = FHServer started.
Process= diskWatcher
Pid    = 12800
RC     = 0
Signo  = 0
Info   = diskWatcher initialized OK.
Process= DFMMultiProcLogger
Pid    = 8232
RC     = 0
Signo  = 0
Process= DFMLogServer
Pid    = 448
RC     = 0
Signo  = 0
Process= DFMCTMStartup
State  = Administrator has shut down this server
Pid    = 0
RC     = 0
Signo  = 0
Stop   = 7/21/2010 9:59:14 AM
Process= DfmBroker
Pid    = 4220
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:48:20 AM
Process= DfmServer
Pid    = 12528
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:48:24 AM
Info   = DfmServer initialized OK.
Process= DfmServer1
Pid    = 12816
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:48:25 AM
Info   = DfmServer1 initialized OK.
Process= DCRDevicePoll
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= CSSCPServer
Pid    = 9656
RC     = 0
Signo  = 0
Process= CSRegistryServer
Pid    = 11488
RC     = 0
Signo  = 0
Info   = CSRegistryServer is running in other process
Process= CSDiscovery
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= CmfDbEngine
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= CmfDbMonitor
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= DCRServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= CMFOGSServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= CampusOGSServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= EssentialsDM
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= ConfigMgmtServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= ICServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= RMEOGSServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= PMCOGSServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= TISServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= DFMOGSServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= InventoryCollector
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= Interactor
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= InventoryCollector1
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= Interactor1
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= NOSServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= PTMServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= UPMProcess
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= EDS-GCF
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= jrm
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= 1301
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= 1303
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= 1304
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= 1306
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= CTMJrmServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= ChangeAudit
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= SyslogAnalyzer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= DataPurge
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= IPMProcess
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= IPMOGSServer
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= TISDiscoveryJobCreate
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= ANIDbEngine
Pid    = 1496
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:51:51 AM
Process= ANIServer
State  = Running with busy flag set
Pid    = 5972
RC     = 0
Signo  = 0
Start  = 7/21/2010 9:51:55 AM
Info   = ANIServer started.
Process= UTMajorAcquisition
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= MACUHIC
Pid    = 7632
RC     = 0
Signo  = 0
Info   = Started.
Process= UTLITE
Pid    = 5592
RC     = 0
Signo  = 0
Info   = Started.
Process= UTManager
Pid    = 0
RC     = 0
Signo  = 0
Start  = N/A
Process= VNMServer
Pid    = 9312
RC     = 0
Signo  = 0
Process= WlseUHIC
Pid    = 14304
RC     = 0
Signo  = 0
Info   = Started.
Process= AdapterServer1
Pid    = 5012
RC     = 0
Signo  = 0
Pid    = 9580
RC     = 0
Signo  = 0
-- More  --
Joe Clarke Wed, 07/21/2010 - 20:57
Follow the instructions in the document https://supportforums.cisco.com/docs/DOC-8796 to perform transaction log recovery on the cmf database.  Hopefully that is all that's required here.  If that does not work, it could be that the cmf database is corrupt.  Check the Event Viewer for errors.
