Cisco ASA to Openswan Error: no matching crypto map entry for remote proxy
Jul 16th, 2010
I've been playing around with configs in both openswan and the ASA to try and get it working properly. I did have them talking with a dynamic crypto map set, but there would be issues after a powercycle on either device. Now im having trouble getting them to talk with static crypto maps. The full error is:
no matching crypto map entry for remote proxy 10.10.10.0/255.255.255.0/0/0 local proxy 192.168.1.0/255.255.255.0/0/0   on interface outside.
My asa config:
hostname ciscoasa
enable password  8Ry2YjIyt7RRXU24 encrypted
passwd  2KFQnbNIdI.2KYOU encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 192.168.1.1  255.255.255.0
interface  Vlan2
nameif outside
security-level 0
ip address 200.200.200.1  255.255.255.0
interface  Ethernet0/0
switchport access vlan  2
interface  Ethernet0/1
interface  Ethernet0/2
interface  Ethernet0/3
interface  Ethernet0/4
interface  Ethernet0/5
interface  Ethernet0/6
interface  Ethernet0/7
ftp mode  passive
access-list inbound  extended permit udp any any eq  isakmp
access-list  inbound extended permit udp any any eq  4500
access-list  inbound extended permit esp any  any
access-list NONAT  extended permit ip 192.168.1.0 255.255.255.0 192.168.2.0  255.2
55.255.0
access-list outbound_tunnel extended permit ip  192.168.1.0 255.255.255.0 192.168.2.0  25
5.255.255.0
pager lines 24
logging enable
logging  timestamp
logging buffered  debugging
logging asdm  informational
mtu inside 1500
mtu outside 1500
ip local pool name  192.168.1.40-192.168.1.60
icmp  unreachable rate-limit 1 burst-size  1
no asdm history  enable
arp timeout 14400
global  (outside) 1 interface
nat (inside) 0  access-list NONAT
nat (inside) 1  0.0.0.0 0.0.0.0
access-group inbound in  interface outside
route  outside 0.0.0.0 0.0.0.0  200.200.200.0
timeout xlate  3:00:00
timeout conn 1:00:00 half-closed  0:10:00 udp 0:02:00 icmp  0:00:02
timeout  sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat  0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00  sip-disconnect  0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00  absolute
timeout  tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record  DfltAccessPolicy
http  server enable
http 192.168.1.0 255.255.255.0  inside
no snmp-server  location
no snmp-server  contact
snmp-server enable traps snmp  authentication linkup linkdown  coldstart
crypto ipsec transform-set ts2 esp-3des  esp-md5-hmac
crypto  ipsec security-association lifetime seconds  28800
crypto  ipsec security-association lifetime kilobytes  4608000
crypto map emap  10 match address inbound2
crypto  map emap 10 set peer  192.168.92.128
crypto map  emap 10 set transform-set ts2
crypto map emap  interface outside
crypto isakmp  enab
crypto isakmp policy 10
authentication pre-share
encryption  3des
hash md5
group 2
lifetime 86400
telnet timeout 5
ssh  timeout 5
console timeout 0
management-access  inside
dhcpd auto_config  outside
dhcpd address  192.168.1.5-192.168.1.36  inside
dhcpd enable  inside
threat-detection  basic-threat
threat-detection statistics  access-list
no  threat-detection statistics  tcp-intercept
webvpn
username ryan password .MqBmFV5KQ86DWrJ  encrypted
tunnel-group  200.200.200.2 type ipsec-l2l
tunnel-group  200.200.200.2 ipsec-att
pre-shared-key *
class-map  inspection_default
match  default-inspection-traffic
policy-map  type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect  ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
   inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
   inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
   inspect tftp
service-policy global_policy global
prompt  hostname context
Cryptochecksum:26b17c4d709bc72a3d76158f2c9997bd
:  end
My openswan config:
conn tunnelipsec
    type=tunnel
    authby=secret
    left=192.168.92.128
    leftnexthop=192.168.92.2
    leftsubnet=10.10.10.0/24
    right=200.200.200.1
    rightnexthop=200.200.200.2
    rightsubnet=192.168.1.0/24
    esp=3des-md5
    keyexchange=ike
    pfs=no
    auto=start
iptables:
$IPTABLES -A INPUT -p udp  --dport 500 -j ACCEPT
$IPTABLES -A  OUTPUT -p udp  --dport 500 -j ACCEPT
$IPTABLES -A INPUT -p udp   --dport 4500 -j ACCEPT
$IPTABLES -A OUTPUT -p udp  --dport 4500 -j  ACCEPT
$IPTABLES -A OUTPUT -p udp  --sport 4500 -j ACCEPT
$IPTABLES -t mangle -A PREROUTING -i eth0 -p esp -j MARK --set-mark 1
$IPTABLES -A FORWARD -i eth0 -m mark --mark 1 -s 10.10.10.0 -d 192.168.1.0/24 -j ACCEPT
Hybrid461 Fri, 07/16/2010 - 06:14
FINALLY figured it out. I changed the outbound_tunnel ACL to a number instead of a name. IMO that's a pretty dumb fix. So everything worked. But then i rebooted to test if it would work after reboot(which it didnt with a dynamic map). But i forgot to save my config changes. So i changed it to a numbered ACL. But i just get repeated: Received encrypted packet with no matching SA, dropping. Only other change ive tried from posted config is setting crypto map emap 10 set peer 200.200.200.2
Edit: Clearing out the SAs worked. Commands:
asa# clear crypto isakmp
asa# clear crypto ipsec sa
