embedded event manager in 12.2(33)SXI3
Answered Question
Jul 16th, 2010
I am trying to register a policy but I am getting the following error:
267808: Jul 16 12:19:25.216 GMT: %HA_EM-6-FMPD_EEM_LOG_MSG: Register event failed: Error empty reg spec, policy does not start with EEM registration command
The first lines of the script are :
::cisco:eem::event_register_timer watchog time $cputimer
namespace import ::cisco::eem::*
I have defined the following environmental variables which are used later in the script:
#show event manager environment
No.  Name                          Value
1    cputimer                      5
2    mincpu                        5
3    fhandle                       disk0:/cpu_output.txt
The policies are in EEM:
dir
Directory of disk0:/
    1  -rw-        8677  May 28 2010 11:53:56 +00:00  startup-config
    2  -rw-   150725900  May 28 2010 12:02:58 +00:00  s72033-ipservicesk9_wan-vz.122-33.SXI3.bin
    3  -rw-         790   Jul 9 2010 09:58:38 +00:00  cpuinfo
    4  drw-           0  Jul 16 2010 08:05:38 +00:00  EEM
dir
Directory of disk0:/EEM/
    5  -rw-        1101  Jul 16 2010 11:49:16 +00:00  cpuinfowatchdog.tcl
    6  -rw-        1101  Jul 16 2010 12:04:34 +00:00  tm_cpuinfowatchdog.tcl
1024196608 bytes total (873299968 bytes free)
router#show event manager directory user policy
disk0:/EEM
router(config)#event manager policy cpuinfowatchdog.tcl type user
Embedded Event Manager configuration: failed to retrieve intermediate registration result for policy cpuinfowatchdog.tcl
router(config)#
267810: Jul 16 12:35:03.348 GMT: %HA_EM-6-FMPD_EEM_LOG_MSG: Register event failed: Error empty reg spec, policy does not start with EEM registration commands.
Any hints ?
Thanks in advance,
Correct Answer by cwildes about 6 years 7 months ago
You are missing an extra colon between cisco and eem in this event registration line:
Clyde Wildes
Overall Rating: 5 (1 ratings)
Joe Clarke Fri, 07/16/2010 - 08:28
You're missing a colon.  Your first line must be:
::cisco::eem::event_register_timer watchdog time $cputimer
Correct Answer
cwildes Fri, 07/16/2010 - 08:30
Clyde Wildes
mkhalil10 Wed, 08/05/2015 - 00:55
Hi all
Am facing the same issue and I have checked the colons but it keep give me errors when trying to commit my configuration
Any other issues could cause this?
BR,
Mohammad
Joe Clarke Wed, 08/05/2015 - 10:12
Please start a new thread for your issue.  Post your current script and the error you're getting.
