How can CVP VXML send ISUP message to PGW softswitch
Jul 16th, 2010
I need to pass ISUP message from CVP VXML server diretctly or through the gateway to PGW. so the question is how and can CVP VXML Studio overwrite the normal nodes and send a direct VXML command to the voice gateway and then a question in the gateway how does it get that command to the PGW?
Muhammad Amir Raza Sun, 07/18/2010 - 23:29
Only PGW can speak ISUP language. In studio you can use custom elements.
What target you are trying to achieve, kindly explain.
Muhammad Amir Raza
