AnyConnect PLAP and Windows 7
Jul 16th, 2010
I have the AnyConnect client installed and working under Windows 7 - and also have it working using the Pre-Login Access Provider feature.
The user invokes the Network Connect component by clicking Switch User, then the Network Connect icon in the lower, right-hand part of the screen.
Is there anyway to make Windows 7 start the Network Connect directly upon boot - without the user having to invoke the Switch User option?
I want to build a system that only presents them the VPN option - with no option of logging in locally.
CCL Network Ser... Wed, 05/18/2011 - 08:45
We are also having a major roadblock just because of this issue.Perhaps need to check other alternatives as Checkpoint/Juniper .
Backendsupport Thu, 12/29/2011 - 05:24
Did you ever manage to solve this? Was this feature added? Right now we are considering Microsoft DirectAccess to solve this issue and NOT use AnyConnect....
Related Content
