Outbound Option Retries
Answered Question
Jul 16th, 2010
Hello:
Quick question... We're running ICM version 7.2 with the Outbound Option.  The department using the Outbound Option doesn't want a retry if the "Customer Not Home" condition is met.  They want one retry for the other conditions (No Answer, Busy, etc.).
I don't see any way to "disable" one specific retry condition.  However (and the manual doesn't specifically call this out), I was wondering if setting the Retry minutes to 0 would disable the specific condition.
Has anyone tried this?
Thanks for your feedback!
Ken
Correct Answer by khambetea about 6 years 6 months ago
I have tried this with a new data file importing daily. Setting the value to a 99999 prevents retries.
Overall Rating: 5 (1 ratings)
khambetea Fri, 07/16/2010 - 13:30
You can change the default values of the settings in campaign manager in ICM config manager to a high value like 9999. This will prevent retry for that condition.
Correct Answer
khambetea Fri, 07/16/2010 - 13:31
Ken Douglas Fri, 07/16/2010 - 13:33
Thank you... Not the answer I was expecting but makes sense since our calling windows are just a few hours, this
would certainly prevent a call back.
Ken
khambetea Fri, 07/16/2010 - 13:35
Agreed. Would be nice to explicitly disable rather than trick the system.
