Deny access to my 3 servers from any host not in my network
Answered Question
Jul 16th, 2010
Hi every body,
I have known last days that some robots ( or hackers) I dont know extactly , but some atacks which coming from the WAN (Internet) try to access to 3 SIP servers in our LAN to register their account.
Now I want to deny any host out of my LAN to access my 3 SIP servers via the 5060 to 5080 ports by indentify the ip server and the ip source.
I want to do it in my CATALYST 2950 where are connected also the router managed by our internet provider and the 3 SIP servers.
Is that possible and how can I do that ( I have never configured ACL in a cisco equipment and don't want to do errors which can stop all activities in our trafic)
Thanks everybody
PS: Server Ip adress : 192.168.1.2  / 192.168.1.242 / 192.168.11.252
                                 So all host in this network 192.168.1.0 and 192.168.11.0 can access to the 3 SIP servers but the others must be deny only by the
                                 ports 5060 to 5080 ( because the technical support access to the servers via ssh or telnet  or http)
Correct Answer by Ganesh Hariharan about 6 years 10 months ago
Yes it's great,
I think that will be ok. I'll try it tomorrow because not at job.
But for the last line why "Switch(config-if)# ip access-group 102 in" I think it wwill be "Switch(config-if)# ip access-group 1110 in" for your example.
I'll tell you tomorrow
Thanks and regards.
PS: Also for my personal knowledge does this ACL do the same thing but now we apply it where for example the server 192.168.1.2 is connected on the catalyst
Switch(config)# access-list 110 permit ip 192.168.1.0  0.0.0.255 host 192.168.1.2 range 5060 5080
Switch(config)# interface gigabitethernet0/1
Switch(config-if)# ip access-group 110 in
I am sorry that was type error, the above example of acl which youu have written that of no need as the server and the source are in same subnet and as per your requirement you need to give permission to local lan subnet apart from internet users on port range 5060 to 5080.
so try the configuration in my previous post and share the results.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Overall Rating: 5 (3 ratings)
Ganesh Hariharan Fri, 07/16/2010 - 11:29
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Hi every body,
Thanks everybody
If i understand the requirement is only local lan can access these server not any body from internet on ports 5060 and 5080
Apply this ACL in the port from where the router cable is getting connected i means from where the internet traffic is coming to your local lan
Switch(config)# access-list 110 deny tcp any host 192.168.1.2 range 5060 5080
Switch(config)# access-list 110 deny tcp any host 192.168.1.242 range 5060 5080
Switch(config)# access-list 110 deny tcp any host 192.168.11.0  range 5060 5080
Switch(config)# access-list 110 permit ip any any
The above ACL will block any traffic source on your three servers on port 5060 to 5080 and as remaing host are in local lan they will able to access these servers.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_37_se/configuration/guide/swacl.html#wp1285529
Hope to Help !!
Ganesh.H
eclipse81 Fri, 07/16/2010 - 12:47
Yes it's great,
Thanks and regards.
Correct Answer
Ganesh Hariharan Sat, 07/17/2010 - 00:26
Yes it's great,
Thanks and regards.
Hope to Help !!
Ganesh.H
eclipse81 Sat, 07/17/2010 - 08:26
Hi mr garnesh,
I do what you tell me to do but I can affect this ACL into an interface of my catalyst?!!!
I don'k know why ( may be my catalyst os version or an upgrading is missing) but this is what i get finaly
Swich(config-if)#ip access-group 110 in
% Invalid input detected at '^' marker.
Swich(config-if)#ip ?
Interface IP configuration subcommands:
  dhcp  DHCP
  igmp  IGMP interface commands
Swich#show version
IOS (tm) C2950 Software (C2950-I6Q4L2-M), Version 12.1(22)EA4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by cisco Systems, Inc.
Compiled Wed 23-Mar-05 15:33 by yenanh
Image text-base: 0x80010000, data-base: 0x80562000
ROM: Bootstrap program is C2950 boot loader
Swich uptime is 24 weeks, 5 days, 23 hours, 11 minutes
System image file is "flash:/c2950-i6q4l2-mz.121-22.EA4.bin"
cisco WS-C2950-24 (RC32300) processor (revision R0) with 21039K bytes of memory.
Processor board ID FCZ0925Y09A
Last reset from system-reset
Running Standard Image
24 FastEthernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:14:6A:44:18:00
Motherboard assembly number: 73-5781-13
Power supply part number: 34-0965-01
Motherboard serial number: FOC09211JFL
Power supply serial number: DAB090835E0
Model revision number: R0
Motherboard revision number: A0
Model number: WS-C2950-24
System serial number: FCZ0925Y09A
Configuration register is 0xF
Swich#
Ganesh Hariharan Sun, 07/18/2010 - 01:18
Hi mr garnesh,
  dhcp  DHCP
Swich#show version
Check out the below link for configuring ACL in cisco 2950 series switches with example and procedure.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2950/software/release/12.1_19_ea1/configuration/guide/swacl.html
Hope to help !!
Ganesh.H
Nagaraja Thanthry Mon, 07/19/2010 - 14:13
  • Cisco Employee,
2950 switches are pure layer 2 switches. So, you can apply the access-list only to the VLAN SVI. Per the document:
The ip access-group interface configuration command is only valid when applied to a management interface of a Layer 2 interface. ACLs cannot be applied to interface port-channels.
Hope this helps.
NT
eclipse81 Tue, 07/20/2010 - 02:08
Okay I think so.
I have also another catalyst (2960) and I connect my router on this catalyst and apply the ACL.
It's working now.
Thanks every body for help me.
PS: I get you but what do you mean when you say VLAN SVI ( I know VLAN but SVI????)
Nagaraja Thanthry Tue, 07/20/2010 - 08:13
  • Cisco Employee,
The SVI refers to the layer 3 interface on the switch (Switch virtual interface).
NT
