Tracking down a unknown IP
Jul 16th, 2010
Can some one help me figure out how to track down this rogue device on the
network. I noticed it in my Kiwi Syslog  server. It shows a hostname of 10.0.0.7. I can ping it, but I cannot seem to locate it. I have tried using Nmap with the following results:
Starting Nmap 5.30BETA1 ( http://nmap.org ) at 2010-07-15 09:02 Eastern Daylight Time
NSE: Loaded 117 scripts for scanning.
Initiating Ping Scan at 09:02
Scanning 10.0.0.7 [7 ports]
Completed Ping Scan at 09:02, 0.09s elapsed (1 total hosts)
Initiating Parallel DNS resolution of 1 host. at 09:02
Completed Parallel DNS resolution of 1 host. at 09:02, 0.00s elapsed
Initiating SYN Stealth Scan at 09:02
Scanning 10.0.0.7 [1000 ports]
Completed SYN Stealth Scan at 09:02, 0.16s elapsed (1000 total ports)
Initiating UDP Scan at 09:02
Discovered open port 123/udp on 10.0.0.7
Completed UDP Scan at 09:02, 4.25s elapsed (1000 total ports)
Initiating Service scan at 09:02
Scanning 1000 services on 10.0.0.7
Service scan Timing: About 0.40% done
Discovered open port 161/udp on 10.0.0.7
Discovered open|filtered port 161/udp on 10.0.0.7 is actually open
Service scan Timing: About 3.30% done; ETC: 10:20 (1:15:42 remaining)
Service scan Timing: About 6.30% done; ETC: 10:03 (0:57:45 remaining)
Service scan Timing: About 9.30% done; ETC: 09:57 (0:50:23 remaining)
Service scan Timing: About 93.30% done; ETC: 09:46 (0:02:58 remaining)
Completed Service scan at 09:46, 2638.84s elapsed (1000 services on 1 host)
Initiating OS detection (try #1) against 10.0.0.7
Initiating Traceroute at 09:46
Completed Traceroute at 09:46, 0.03s elapsed
Initiating Parallel DNS resolution of 2 hosts. at 09:46
Completed Parallel DNS resolution of 2 hosts. at 09:46, 0.05s elapsed
NSE: Script scanning 10.0.0.7.
NSE: Starting runlevel 1 (of 2) scan.
Initiating NSE at 09:46
NSE Timing: About 96.30% done; ETC: 09:59 (0:00:30 remaining)
NSE Timing: About 96.30% done; ETC: 10:00 (0:00:31 remaining)
NSE Timing: About 96.30% done; ETC: 10:21 (0:01:17 remaining)
Completed NSE at 10:21, 2078.55s elapsed
NSE: Starting runlevel 2 (of 2) scan.
Initiating NSE at 10:21
Completed NSE at 10:21, 5.02s elapsed
NSE: Script Scanning completed.
Nmap scan report for 10.0.0.7
Host is up (0.00s latency).
Not shown: 1000 closed ports, 998 open|filtered ports
PORT    STATE SERVICE VERSION
123/udp open  ntp     NTP v4
| ntp-info:
|   receive time stamp: 07/15/10 09:46:36
|   system: cisco
|  leap: 0
|   stratum: 2
|   rootdelay: 25.53
|   rootdispersion: 6.96
|   peer: 511
|   refid: 156.34.21.3
|   reftime: 0xCFE98F9B.EF8BC22B
|   poll: 6
|   clock: 0xCFE98FB1.E0211428
|   phase: -0.462
|   freq: -176.82
|_  error: 0.75
161/udp open  snmp    Cisco SNMP service
Warning: OSScan results may be unreliable because we could not find at least 1 open and 1 closed port
Device type: switch|WAP
Running: Cisco IOS 12.X
OS details: Cisco 3750 switch (IOS 12.2), Cisco Aironet 1231G WAP (IOS 12.3)
Network Distance: 2 hops
Host script results:
|_ipidseq: Randomized
| qscan:
| PORT   FAMILY  MEAN (ms)  STDDEV  LOSS (%)
| 1      0       62.50      0.53    0.0%
| 3      0       62.80      0.42    0.0%
|_65389  0       62.30      0.48    0.0%
TRACEROUTE (using port 113/tcp)
HOP RTT     ADDRESS
1   0.00 ms 192.168.2.3
2   0.00 ms 10.0.0.7
Read data files from: C:\Program Files\Nmap
OS and Service detection performed. Please report any incorrect results at http://nmap.org/submit/ .
Nmap done: 1 IP address (1 host up) scanned in 4739.89 seconds
           Raw packets sent: 13027 (543.796KB) | Rcvd: 1022 (41.304KB)
It looks like the router hop goes off of one of my L3 switches, but when I do a "sh arp | include 10.0.0.7", I don't get anything. How can I track this down to a port?
Nagaraja Thanthry Fri, 07/16/2010 - 11:18
  • Cisco Employee,
You can do it in two steps:
Step 1: As long as it is in the same IP subnet, ping the IP address. Then,
check the ARP cache
Step 2: Now on the switch, issue "show mac address-table | include "
That will give you the exact port where the IP is connected to.
Hope this helps.
NT
Ganesh Hariharan Fri, 07/16/2010 - 11:40
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
| ntp-info:
|   system: cisco
|  leap: 0
|   stratum: 2
|   rootdelay: 25.53
|   peer: 511
|   refid: 156.34.21.3
|   poll: 6
|   phase: -0.462
|   freq: -176.82
|_  error: 0.75
As Suggested by NT first ping frm local switch and then issue command show mac-address to find the ip address assoiated with the mac and mac learning from the port.
Hope to Help !!
Ganesh.H
oneirishpollack Fri, 07/16/2010 - 21:55
Help me out with this.
192.168.2.3 is my internal router. When I ping two devices: 10.4.4.30 and the unknown device 10.0.0.7 I get replies. When I do a 'show arp', I fail to get a MAC for the 10.0.0.7 address, though I do get one for the 10.4.4.30 address.
L1-router2# sh arp | include 10.4.4.30
Internet  10.4.4.30               1   0019.b973.b5c9  ARPA   Vlan4
L1-router2# sh arp | include 10.0.0.7
L1-router2#
Leo Laohoo Fri, 07/16/2010 - 23:49
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
MAC address of "0019.b973.b5c9" is a Dell client.
Ganesh Hariharan Sat, 07/17/2010 - 01:45
L1-router2#
Try ping from the switch where you can thing it is connected and the try show arp or show mac-address.
Hope to Help !!
Ganesh.H
oneirishpollack Sat, 07/17/2010 - 18:10
I relocated this to the correct response.
In addition, the 10.4.4.30 address was just to verify that ARP was working on the switch, The 10.0.0.7 address is the IP I am trying to discover.
Richard Burts Sat, 07/17/2010 - 05:29
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
The output from NMAP indicates that the device is 2 hops away. In this case there would not be an ARP entry in the local router (since ARP is for locally connected devices). I would suggest doing a traceroute to the 10.0.0.7 address. Go to the last device that responded, and do the show arp on that device.
Rick
oneirishpollack Sat, 07/17/2010 - 19:27
Re:  Tracking down a unknown IP
Thanks for all the help thus far. Here  is the situation....
The trace route (tracert) from my workstation  (10.9.9.50/24) to 10.0.0.7 shows this...
"Tracing route to 10.0.0.7 over a  maximum of 30 hops
  1     3 ms     4 ms     4 ms  192.168.2.3
  2     1  ms    <1 ms    <1 ms  10.0.0.7
Trace complete."
Trace ip  10.0.0.7 from my internal router (192.168.2.3) maxes out:
"L1-router2#trace  ip 10.0.0.7
Type  escape sequence to abort.
Tracing the route to 10.0.0.7
  1  *  *  *
   2  *  *  *
  3  *  *  *
  4  *  *  *
  5  *  *  *
  6  *   *  *
29  *  *  *
30  *  *  *"
So 10.0.0.7, the "rogue" device I am trying to locate appears to be connected to 192.168.2.3 (VLANs used) based on the results of my trace route. Why doesn't the MAC show up in the mac-address table of 192.168.2.3 or the IP/MAC in the ARP table?
oneirishpollack Tue, 07/20/2010 - 08:33
So I verified that the tracert:
  1    <1 ms    <1 ms    <1 ms  192.168.2.3
Trace complete.
10.0.0.7 is the device in question, but it's IP is not in the ARP table of the router.
L1-router2#sh arp | include 10.0.0.7
L1-router2#
Any reasons why this might be?
