Macintosh VPN Client
Answered Question
Jul 16th, 2010
We are running MAC Snow Leopard (ver. 10.6.2).  Is there a way to copy the profile instead of giving the user the instruction how to configure the VPN client?  I do not want to give out the group name and the group password.
Thanks.
Laura
Correct Answer by Jennifer Halim about 6 years 10 months ago
Unfortunately Mac Snow Leopard (v. 10.6) uses built-in Apple vpn client which is provided by Apple, not Cisco, hence it does not support PCF file.
Correct Answer by manish arora about 6 years 10 months ago
YUP , use the pcf files and have the user import them on the vpn client software. For example :-
if you have windows box --> program files ---> cisco  system --> vpn client --> profiles --> .pcf files.
so, you can configure your desktop's v[pn client with all the information and save it. Then access these pcf files , which you can provide to  users so that they can import them on their vpn client. The same cisco pcf files are compatible with open source "shrewsoft client app " too.
Hope it helps
thanks
manish
Overall Rating: 5 (2 ratings)
Correct Answer
manish arora Fri, 07/16/2010 - 12:06
  • Silver, 250 points or more
Hope it helps
thanks
manish
Correct Answer
Jennifer Halim Sat, 07/17/2010 - 15:16
  • Cisco Employee,
