1250 LWAPP TO AUTONOMOUS
Answered Question
Jul 16th, 2010
I can't seem to find the image for upgrading a 1250 from LWAPP to Autonomous?
Also do I need the upgrade tool? If so where can I find it? (No Controller)
Please can someone point me in the right direction?
Many Thanks.
Correct Answer by Kayle Miller about 6 years 7 months ago
jcomment,
     There is an IOS image for the 1250 series AP on cisco's site, you must have a CCO account to access this. If you have access to that goto www.cisco.com, click on support> Download Software> Wireless> Access Points> Cisco Aironet 1250 Series> Cisco Aironet 1250 Series Access Point
then select IOS Software and you should get a list of versions.
In terms of converting this the easiest way is to use the mode button and do a reset.
Step 1 set your computer to 10.0.0.100 255.255.255.0
Step 2 Place image file into a TFTP server folder on your PC.
Step 3 Rename the access point image file in the TFTP server folder to c1250-k9w7-tar.default.
Step 4 Using an ethernet cable connect your PC to the power injector/AP
Step 5 Disconnect power from the access point.
Step 6 Press and hold the MODE button while you reconnect power to the access point.
Step 7 Hold the MODE button until the Radio LED turns a red color (approximately 20 to 30 seconds), and release the MODE button.
Step 8 it will download the firmware image and decompress it.
Step 9 After the access point reboots, you must reconfigure the access point by using the Web interface, the Telnet interface, or Cisco IOS commands.
Hope this helps....   Please rate helpful posts.
Kayle
Overall Rating: 5 (1 ratings)
Correct Answer
Kayle Miller Fri, 07/16/2010 - 12:43
jcomment,
Kayle
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
