copy all files from a flash
Jul 16th, 2010
Hi all.  I am trying to copy all files from a flash: on a CME to a usbflash drive.  I am able to do so, but only one at a time.  Is there a away to copy all files at one time so I dont have to name them individually when copying all of them over?  Thanks.
Overall Rating: 5 (1 ratings)
Reza Sharifi Fri, 07/16/2010 - 14:02
  • Cisco Designated VIP,
    2017 LAN
As far as I know, there in no such command on the router that you can use to do massive copy and paste.
Reza
Leo Laohoo Fri, 07/16/2010 - 23:52
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
    2017 LAN, Wireless
Try "copy flash:. usbflash0:".
Ganesh Hariharan Sat, 07/17/2010 - 01:31
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Check out the below link hope to help !!
https://cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800a6744.shtml
Ganesh.H
Imthiyas Khan K I Sun, 10/19/2014 - 18:25
  • Bronze, 100 points or more
Hi jjoseph01,
The best was is to tar all the files to your PC first, using the below command.
archive tar /create tftp://192.168.10.200/Flash_Files.tar flash:
Once all the files are copied to the tftp server,  it is easy to untar all the files to USB drive.
Imthiyas Khan
mike.b.simpson Tue, 01/31/2017 - 08:40
This worked well for me, at least for my use case, which was a path with only files in it.  Thank you.
Imthiyas Khan K I Wed, 02/01/2017 - 20:51
Hi Mike,
I am glad to hear that your issue is resolved.
Please rate if it really helps you :)
