Show attached clients on a WAP2000?
David Hornstein Mon, 07/19/2010 - 22:07
  • Gold, 750 points or more
Hi Eric,
I haven't check Version 2.0.0.5 software, but older software.
I found it under the tab wireless> wireless connection control>wireless client list.  As the help text in the AP states;
"By clicking this option, you will see a MAC table that will display the wireless PCs that are already wirelessly connected to the Access Point."
Or if you wish as an alternative,  check the MAC address table on the managed switch that the AP is connected to as a alternative if you wish.
This should show you that MAC addresses on the same switch port as the AP.
Hope this helps
David
