cutting off all sorts of "p o r n" on 877 router
Jul 17th, 2010
Can anyone give me a tip on creating firewall rules to ideally cut off any kind of porn access or at least significantly limiting and making it difficult?
Thank you!
Overall Rating: 5 (1 ratings)
Zenith888 Sat, 07/17/2010 - 07:13
Oh, this is ridiculous! We are in a router support forum and they are censoring the word which is the reason most firewalls exist.
My post is about P O R N and getting rid of it, how on Earth can I ask question if the word is censored?
paolo bevilacqua Sat, 07/17/2010 - 22:04
  • Hall of Fame,
    Founding Member
By replacing it with "questionable content"
Mohamed Sobair Sun, 07/18/2010 - 01:18
  • Gold, 750 points or more
here are some options:
1- using AAA or Tacacas authentication servers for access.
2- limiting the Access to specific source IPs.
3- create different user privileges.
Mohamed
paolo bevilacqua Sun, 07/18/2010 - 01:41
  • Hall of Fame,
    Founding Member
And how exactly ???
So people will start changing their IP addresses
Like how exactly ?
paolo bevilacqua Sun, 07/18/2010 - 04:32
  • Hall of Fame,
    Founding Member
What I misunderstood here?
That all the OP wants, is to cut off user'.s access to "questionable content".
paolo bevilacqua Sun, 07/18/2010 - 14:23
  • Hall of Fame,
    Founding Member
Open DNS works great for us at our  small school.
Check for kids using IP addresses instead
Zenith888 Sun, 07/18/2010 - 09:26
But go on! What commands should I issue to the router to disallow access to pornographic web sites and d/ling porn via p2p and bittorents?
Nagaraja Thanthry Mon, 07/19/2010 - 08:02
  • Cisco Employee,
Hello Zen,
You have few different ways of doing it.
1. Use a URL filter like WebSense on N2H2.The router will redirect URL request to the URL Filter server and server will approve/reject the request. Based on that the router will either forward the request to the internet or send a deny page.
http://www.cisco.com/en/US/docs/ios/sec_data_plane/configuration/guide/sec_fwall_websense.html
2. Use a content filtering solution which is more granular and will look for any offensive content and block it. You need a content filter module either installed on the router or you need to have a third-party solution
https://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6643/prod_qas0900aecd804abb06.html
3. Use a proxy to access internet. Configure proxy with parental controls. This could be somewhat economical given that there are some implementations that could be run on a linux box. But the only problem with this solution will be scalability and reliability.
Hope this helps.
NT
Mohamed Sobair Mon, 07/19/2010 - 12:06
Paolo,
I know its a problem being sensitive to each word, I shouldnt be .. and I have also been over stressed a bit.
So I apologize, I do much respect you!!
Mohamed
paolo bevilacqua Tue, 07/20/2010 - 18:20
  • Hall of Fame,
    Founding Member
No problem. I have edited my post, as it was a bit harsh indeed. And have rated your.
paolo bevilacqua Sun, 07/18/2010 - 14:20
  • Hall of Fame,
    Founding Member
Mohamad, you are wrong. The OP was perfectly clear in his post, but your answer was not addressing the problem, and I simply remarked that.
All the rest is unnecessary rambling by your side, that you could have spared. Thank you however for providing the link to content URL filtering.
I personally have no bad feelings, so take care.
Mohamed Sobair Sun, 07/18/2010 - 01:50
Hi Paolo,
what I understood the poster needs to limit access credential to the router being accessed by everyone, the word (P O R N) access what made me assumes this.
Mohamed
Mohamed Sobair Sun, 07/18/2010 - 11:36
Paolo,
I was waiting for your answer, and you didnt mention any thing in detailed explanation, However, I was also waiting for the Original poster to understand his delima as HIS QUESTION WASNT CLEAR.
I was actually very surprised about your offensive reply and abusement, but I have decided to better send you this message rahter than any thing else. Kindly read the following points carefully:-
1- Its me who will decide to refrain from posting not any body else.
2- I beleive it would be more elegant and polite to describe the Original poster question and solution to all of us including me since you know it rather than being offensive.
3- I will not report your previous post as abusing cause I found it sufficient writing those points for you so you would learn from your mistake.
To the Original Poster and ALL :
Please refer to (Cisco IOS Content filtering) in this URL which  should solve your problem, However, be informed that it requires licensing and additional payment. here is the url:
http://cisco.biz/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6643/prod_qas0900aecd804abb06.html
Thanks for reading,
Mohamed
