SSL VPN issue on SDM
Jul 17th, 2010
hi,
im working on the configuration for a ssl vpn, i was trying to configure the tunnel on SDM however it keeps saying that the router needs a digital certificate, the message is this "digital certificates are not configured on this router. You must have a digital certificate for this router to configure SSL VPN Gateways.", however the self-signed certificate is there and i'm able to configure the ssl vpn tunnel through CLI, so i dont know what is the issue in SDM, im using SDM 2.4.1 and have tried SDM 2.5 with the same problem.
Does anyone have any idea what is going on with this?
thanks all for your replies.
rodrigo.cisco Mon, 07/19/2010 - 08:15
Hi Fernando,
I had the same problem and I solve it upgrade the ISO for the last one. I hope that help you too..
