07-17-2010 11:41 AM
I have an SFE2000 operating in Layer 3 mode. I've set up 2 IP addresses on it which are the following:
IP: 172.20.72.22
mask: 255.255.248.0
IP: 172.20.80.252
mask: 255.255.255.0
Under the IP Routing section I've set up routing to the internet by putting in the following:
Destination IP: 0.0.0.0
Prefix: 0
Next Hop: 172.20.72.1 (ip of the internet router)
Client 1 Client2
IP: 172.20.72.8 IP: 172.20.80.206
Mask: 255.255.248.0 Mask: 255.255.255.0
Gateway: 172.20.72.22 Gateway: 172.20.80.252
Client 1 is able to get onto the internet, but Client 2 is not. What do I need to do in order for that to work?
07-19-2010 01:49 AM
IP: 172.20.72.22
mask: 255.255.248.0
IP: 172.20.80.252
mask: 255.255.255.0
Prefix: 0
Client 1 Client2
Just Check the natting is done for second subnet and what is the nat configuration on internet router
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
07-20-2010 06:40 AM
Hi Ganesh,
Can you walk me through what I need to do? I must admit I am getting confused with it all.
