icoming pots dial-peer and port command
Jul 17th, 2010
If a router has multiple voice-port (multiple PRI), do I need to confiure incoming dial-peer for all or just single with no voice-port command is enough?
Overall Rating: 5 (1 ratings)
paolo bevilacqua Sun, 07/18/2010 - 04:41
  • Hall of Fame,
    Founding Member
No port command is needed. The most important command is "incoming called-number".
Note: FXO port are an exception, because these do not have a "called-number".
