E1
Jul 17th, 2010
hi
I have CISCO 7.1  integrated with nortel 81c with 4 PRI-QSIG link, I need to know if its enough for 500 users, if there is any tools in cisco to calculate that,
please provide.
PATRICK GESCHWINDNER Sat, 07/17/2010 - 13:58
This is calculated using the Erlang formula. Free Erlang calculators are available in the internet. Use Erlang B for the calculation of necessary B-Channels (which is what you need). Callcenter calculators are using the Erlang-C formula. Here is only one of the many examples:
Erlang B: http://www.erlang.com/calculator/erlb/
Erlang C: http://www.kooltoolz.com/ccm.htm?gclid=COOX0Jq586ICFUfX5woddySqhQ
Best
  Patrick
Mohammed Al-Assadi Sat, 07/17/2010 - 14:20
Hi Patrick,
I think he is asking about normal users not Contact Center.
Erlang calculation for Call Centers.
Erlang B to calculate IVR and trunk ports ( as you know in IPCC you are expection calls more than agents)
Erlang C to calculate the Agents.
paolo bevilacqua Sat, 07/17/2010 - 22:01
  • Hall of Fame,
    Founding Member
Erlang "calculations" are useless in most cases.
Some users do a lot of calle and some do never calls.
The only working way is to observe real usage of an exisiting trunk.
jontypearce Wed, 11/30/2016 - 06:39
There is also an Erlang C Calculator in Excel format which could help with your calculations
Erlang C Calculator
This also contains shrinkage calculations so will be more accurate.
