Cisco support contract
Jul 17th, 2010
Dear sir,
I need to update my IPS Signature on ASA5510-AIP-SSM automatically, From my local Cisco representative i got 2 product numbers
to obtain the IP address of FTP server , username and password (Cisco support contract)
In this case which one should i use among:
1) CON-SU1-ASAINC10
2) CON-SU1-AS1A10K9
Thanx in advance
Overall Rating: 5 (1 ratings)
Siddharth Chand... Wed, 07/21/2010 - 11:28
  • Cisco Employee,
Hi Hari,
I am not sure if I understood your question correctly.
CON-SU1-ASAINC10 : This is the SMARTNET contract service agreement.
CON-SU1-AS1A10K9 : This is the Cisco Software license agreement.
You mentioned you needed to update the signatures on your ASA5510-AIP-SSM and hence you needed a license key
For that you need to do the following:
1. Make sure the serial number of the AIP-SSM module (not just the ASA) is correctly added to your smartnet contract.
Contact your Cisco rep and verify this.
2. Open a TAC case with problem description "Requesting IPS license for AIP-SSM module with serial number <> "
Hope that helps.
Sid Chandrachud
Customer Support Engineer
Cisco TAC- IDS.
Adam David Wed, 02/15/2012 - 18:38
This is interesting.
1.      What is the difference between SMARNET & Cisco Software license agreements?
2.      What is the meaning of the following code?
     a.     CON
     b.     SU1
     c.      ASAINC10
     d.    AS1A10K9
cvilleme Wed, 07/21/2010 - 12:06
  • Cisco Employee,
I'm not entirely sure I understand your query.  If you're asking, "How do I enable my AIP-SSM-10 sensor to receive automatic IPS signature updates?", then first and foremost you will need to have a valid IPS services license applied to your sensor.  The sensor can function fully without a license, but it cannot receive signature updates without a license.
All you should need to obtain an IPS license key is a valid IPS support contact and the serial number of the AIP-SSM-10 sensor.  You can login at http://www.cisco.com/go/license and follow the instructions there to obtain a license key.  Alternatively, you can email [email protected] and provide the IPS device serial number and this will create an automatic ticket with the Cisco licensing team, who can then generate and email a license key to you.
Once you have a valid license key applied to the sensor, you can automatically apply signature updates by one of two methods.  Method #1 is half manual, half automatic, and method #2 is fully automatic.
Method #1:
Manually download the signature updates and place them on an FTP, SCP, or HTTP/HTTPS server accessible by the sensor, and then point the sensor at the download server to check on a scheduled basis for newly found updates.
Method #2:
Configure the sensor to download the signature update directly from cisco.com and apply it automatically.  For this to work, the sensor needs unfettered HTTP (tcp/80) and HTTPS (tcp/443) access to Cisco's website.
More information on automatic upgrades from Cisco IPS CLI User Guide:
http://www.cisco.com/en/US/docs/security/ips/7.0/configuration/guide/cli/cli_system_images.html#wp1045915
Chris
