MCS 7845-I4-IPC1 / on IBM - Equiv 2 Teaming/ILO how to configure on this box
Answered Question
Jul 17th, 2010
I'mfFinding it impossible to find configuration information  that outlines how to configure the  two NICS (teaming in HP model) and the management port (ILO) for the MCS 7845_I4 IBM equivelant.
Are both NIC's supported for CUCM 7.1.5 also have this I4 server for  Unity Connection 7 / CUCM 7?
I vaguely remeber reading that redundant NICs for Unity connection wasnt supported, could this be correct???
Anyway if someone can point me to the doco for this it would be great.
MCS 7845-I4 - configure management port
MCS 7845-I4 Configure redundant Nics
Correct Answer by Mohammed Al-Assadi about 7 years 3 days ago
Login to CUCM or Unity Connection CLI and add this command:
set network failover enable
Overall Rating: 5 (1 ratings)
allanwells Mon, 07/19/2010 - 14:29
Correct Answer
Mohammed Al-Assadi Mon, 07/19/2010 - 14:35
Andreas Klein Thu, 10/28/2010 - 08:36
Hello, the failover option works very well thanks.
How about the SYS MGMT port that is left on my MCS7825i4 machine?
I can't find any doc on this port and what it does in life, anyone know or have experience using it?
Thanks!
