sRP527w issues
Jul 17th, 2010
I have SRP 527w and I am having a number of issues  1. I cannot connect and print to printers from MacOS platforms regardless of the combination of connection - wired wired /wireless wireless or wired wireless.  I have seen the knowledge based statements from Andy Hickman saying that bonjour is not supported ... Van you advise when it will be and what m options are at the moment ( BTW windows printing works)   2. Are there Any SIP config guides around as I want/ need to set this box up wit a local SIP provider   3. Will the SRP527 support wifi connected sip clients ?  Cheers mark
Andrew Hickman Mon, 08/23/2010 - 03:04
  • Cisco Employee,
Hi Mark,
1. No update for this at the moment.  I'll follow to see what we can do here.
2. Sure - the SRP FXS ports are configured in essentially the same way as the SPA2102.  There's a link from this page.
3. This should be possible, please ensure that you configure WMM and WMM-PS to meet your specific network requirements.
Hope that helps,
Andy
