vpn tunnel opened but unable to ping devices in remote LAN
Jul 18th, 2010
hi all
i use a rv042 router and i try to create a stable vpn connection....
first i tried to use the quick vpn client but there was a strange error. At the beginning i could connect successfully but since the fifth connection i couldnt connect to the router and got the "The remote gateway is not responding......" error message.
i tried to enable/disable the firewall, disabled the "block wan requests", enabled https and checked the ports but without success.
i remembered that the mtu size must be set to a lower value but i cant remember this value anymore....
yesterday i tried to create a client to gateway vpn tunnel. Now its possible to open the tunnel but i cant ping any devices in my remote network...(i'm using thegreenbow vpn client)..
i created a static ip user in my dhcp settings but it's still not working...
i hope that anybody could give me an advice to make my vpn connection working.....
sorry for my bad english
best regards
