A few basic questions on CAS
Jul 18th, 2010
Dear friends,
I am using CAS server 4.7.2.
1. A user was earlier reporting that she was getting prompted for clean access login again and again.
By the time, i went, the problem was resolved.
I checked the perfig-log under /perfigo/logs folder but it did not show any indication.
Is there any other place that i should be looking for at the problem time.
2. Also, i am getting the following error in perfigo-log. Is it common to get this error and is it informational only?
Using JRE_HOME: /usr/java/jdk1.6.0_12
[FAILED]
3. Is there any way to enable verbose logging for NAC client so that we know when he is connecting, disconnecting and so on?
Thanks a lot
Gautam
Faisal Sehbai Mon, 07/19/2010 - 06:31
  • Gold, 750 points or more
Gautam,
Wrong place! In 4.7 look for logs under /perfigo/access/tomcat/logs
Faisal
JUAN HUICAB Wed, 07/21/2010 - 17:40
"A user was earlier reporting that she was getting prompted for clean access login again and again"
I recommend that you check manage subnet and vlan mapping at the CAS the problem could be located at that level.
JUAN HUICAB Wed, 07/21/2010 - 17:50
Also if that client is behind a IP Phone you have to verify the
filter list in order to check if that device is include.
