Webview with windows 7 Proff and IE 8
Answered Question
We are trying to run Cisco webview  from client Machine(windows 7 professional with IE 8) the webview is accessible but when we generate any report we got the below  error Message:
((((Error. The server encountered an unexpected condition which prevented it from fulfilling the request.
java.util.MissingResourceException: Can't find resource for bundle java.util.PropertyResourceBundle, key en-US
                at java.util.ResourceBundle.getObject(ResourceBundle.java:325)
                at java.util.ResourceBundle.getString(ResourceBundle.java:285)
                at pagecompile._webview._ReportNewDateTime_xjsp._jspService(_ReportNewDateTime_xjsp.java:322)
                at com.newatlanta.servletexec.JspHttpJspPage.service(JspHttpJspPage.java:41)
                at com.newatlanta.servletexec.JspServlet.service(JspServlet.java:1036)
                at javax.servlet.http.HttpServlet.service(HttpServlet.java:856)
                at com.newatlanta.servletexec.SERequestDispatcher.forwardServlet(SERequestDispatcher.java:638)
                at com.newatlanta.servletexec.SERequestDispatcher.forward(SERequestDispatcher.java:236)
                at com.newatlanta.servletexec.SERequestDispatcher.internalForward(SERequestDispatcher.java:283)
                at com.newatlanta.servletexec.ApplicationInfo.processApplRequest(ApplicationInfo.java:1827)
                at com.newatlanta.servletexec.ServerHostInfo.processApplRequest(ServerHostInfo.java:937)
                at com.newatlanta.servletexec.ServletExec.ProcessRequest(ServletExec.java:1091)
                at com.newatlanta.servletexec.ServletExec.ProcessRequest(ServletExec.java:1002)))))
any help would be appreciated
Correct Answer by Doan Khanh Tan Thanh about 6 years 7 months ago
There's a the same problem posted here. It is answerred by Geoff.
The procedure is: go to internet option --> language, add a user define: en-us (lower case) and move it up. It work fine with ICM 7.2.7.
Overall Rating: 5 (1 ratings)
Correct Answer
Doan Khanh Tan Thanh Tue, 07/20/2010 - 21:40
shivkumar gadad Tue, 08/06/2013 - 05:24
Thanks for the update, the above workaround solution is working on the user desk, but when i tried fixing it on the server level we didnt get the expected result,
we did add en-US in Webview server and reset the Jaguar and IIS Admin server, also cycle the ICM services on it but it didnt work..
Thanks in advance for the reply
