7960 Legacy POE
Jul 18th, 2010
Will the Cisco small business 24-port 10/100 POE switch (model 'ESW-520-24P') provide POE to my existing 7960 phones?
My office is moving and I am trying to phase out the Powerdsine POE midspan injector+Catalyst 2960 combo we currently have and replace it with one of these.
Our current 7960 phones are each equipped with a POE crossover dongle (I think these are used to provide legacy inline power to the phones from the 802.3af injector source)
Just trying to make sure I order correctly.
Thank you!
Rob Huffman Sun, 07/18/2010 - 07:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Adam,
Q.
Do the Cisco ESW 500 Series PoE switches support Cisco pre-standard Power over Ethernet?
A.
No. For Cisco pre-standard PoE, we recommend the Cisco Catalyst 2960 Series Switches, which support both 802.3af and Cisco pre-standard PoE.
http://www.ciscoguard.com/datasheets/ESW/ESW_500_QandA.pdf
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
