Issues with the Wireless setup of the WVC210 camera
Jul 18th, 2010
I recently purchased the WVC210 Wireless camera.  I have an SMC router (model #SMC8014WG).  I am able to get it up and working on the Ethernet connection.  I entered in the SSID and WEP for my local network as the instructions said and then power cycled the camera with the Ethernet cable disconnected.  The Wireless led on the camera lit up to show that it was connected on the wireless.  However, when I go to the URL to view the camera stream (the IP address that showed the camera strean via the Ethernet connection), it doesn't come up.  Do I need to go to a different IP/URL to view the stream on the wireless?  How do I find out which IP address is being used?
Any suggestions would be great.  Thanks.
Steven DiStefano Mon, 07/19/2010 - 04:02
  • Blue, 1500 points or more
There is the chance the router DHCP IP address assigned to this wifi
MAC changed.
If you have any intentions of viewing this camera from a web browser
or SWVMS16, locally or remotely, best practice is to slap a static IP
on it.
This way you always know where to find it. Plug it back in if you
can't see leased IPs and Macs on your router and make it static, then
wireless.
The mode of operation (wired or wireless) isn't different for camera
viewing.
Steve DiStefano
Technology Solutions Architect - Sales
Cisco Systems
Research Triangle Park
North Carolina, U.S.A
1.919.392.6219
www.cisco.com/smb
On Jul 18, 2010, at 9:43 PM, "shanthisarkar"
