LMS 3.2 Application Registration Issue
Answered Question
Jul 18th, 2010
Using LMS 3.2, there is an issue with Application Registration.
Campus manager 5.2.1 is installed but when viewed in Application Registration Status it says Campus manager 5.2. When new devices are dicovered by Campus Manager it sets the version as 5.2. I have been able to update the device details in the backend PIDM table using SQL. Is there any way of refreshing the Application registration to reflect the installed version of CM by default?
Correct Answer by Joe Clarke about 6 years 8 months ago
The PIDM version of CM 5.2.1 is 5.2.  Check Common Services > Software Center > Software Update.  If you have the 5.2.1 update installed properly, that will say 5.2.1.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Sun, 07/18/2010 - 20:22
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
mburrell5 Sun, 07/18/2010 - 20:48
Yeah the software Update page says CM 5.2.1. sorry, my mistake
