LMS 3.2 causing spikes on routers
kmong
Hi everyone,
A customer reported that their router experienced spikes (high cpu utilization) and claims that it is caused by snmp polling of the Ciscoworks server. What must be done to confirm that it is caused by snmp polling of LMS? If it is really caused by LMS, what values should be set on the polling parameters and threshold?
Looks like the problem is related to VNM polling the MPLS-VPN-MIB.  If you are not using VNM, you can filter out this branch by applying an SNMP view to the community string used by LMS.  For example:
snmp-server view nomplsvpn iso included
snmp-server view nomplsvpn 1.3.6.1.3.118 excluded
snmp-server community mycomm view nomplsvpn RO
To fix this (bug CSCsl78965), you would need to upgrade to 12.2(18)SXF15 or higher.
15 Replies 15
Joe Clarke
When the CPU is spiking, you need to capture the output of "show stack PID" where PID is the process ID of the process which is taking up the CPU (probably either SNMP ENGINE or IP SNMP).  Post this stack trace along with the show version output.  This could be a known bug, or simply an issue with over-polling or polling a large amount of data.
If its polling a large amount of data, what should be done to avoid spikes on the cpu? I'll be posting the output once I've received it.
The polling intervals can be changed, or the data can be spread out over multiple polls.
Polling parameters and thresholds in DFM are still in its default values. What would be the ideal settings? Where else can we change the polling intervals?
It will depend on what part of LMS is causing the CPU spikes.
How will I know which LMS process is causing the spikes? As I have mentioned, the polling parameters and thresholds are just in default value.
That's what the show stack output will indicate.  The objects being polled will indicate which part of LMS is doing the polling.
Ok. This is noted. I will send the output once I receive it from the client. We have no access on their routers
Hi Joseph,
Please see attached output of show version and show stack. Client has reported that the spikes occur every 4 hours (0000H 0400H 0800H so on..)
VAL-IPB-RTR-003#sh  ver
Cisco Internetwork  Operating System Software
IOS (tm) s72033_rp  Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)SXF4, RELEASE  SOFTWARE (fc1)
Technical Support:  http://www.cisco.com/techsupport
Copyright (c)  1986-2006 by cisco Systems, Inc.
Compiled Thu  23-Mar-06 19:38 by tinhuang
Image text-base:  0x40101040, data-base: 0x42DA8000
ROM: System  Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp  Software (s72033_rp-ADVENTERPRISEK9_WAN-M), Version 12.2(18)SXF4, RELEASE  SOFTWARE (fc1)
VAL-IPB-RTR-003  uptime is 4 years, 3 weeks, 1 day, 11 hours, 17 minutes
Time since  VAL-IPB-RTR-003 switched to active is 4 years, 3 weeks, 1 day, 11 hours, 34  minutes
System returned to  ROM by unknown reload cause - suspect boot_data[BOOT_COUNT] 0x0, BOOT_COUNT 0,  BOOTDATA 19 (SP by power on)
System restarted at  04:22:14 GMT Wed Jun 28 2006
System image file  is "disk1:s72033-adventerprisek9_wan-mz.122-18.SXF4.bin"
This product  contains cryptographic features and is subject to United
States and local  country laws governing import, export, transfer and
use. Delivery of  Cisco cryptographic products does not imply
third-party  authority to import, export, distribute or use encryption.
Importers,  exporters, distributors and users are responsible for
compliance with  U.S. and local country laws. By using this product you
agree to comply  with applicable laws and regulations. If you are unable
to comply with U.S.  and local laws, return this product immediately.
A summary of U.S.  laws governing Cisco cryptographic products may be found  at:
If you require  further assistance please contact us by sending email to
export@cisco.com.
cisco CISCO7609  (R7000) processor (revision 1.1) with 983008K/65536K bytes of  memory.
Processor board ID  FOX0835049C
SR71000 CPU at  600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from  power-on
SuperLAT software  (copyright 1990 by Meridian Technology Corp).
X.25 software,  Version 3.0.0.
Bridging  software.
TN3270 Emulation  software.
39 Virtual  Ethernet/IEEE 802.3 interfaces
236 Gigabit  Ethernet/IEEE 802.3 interfaces
1917K bytes of  non-volatile configuration memory.
8192K bytes of  packet buffer memory.
65536K bytes of  Flash internal SIMM (Sector size 512K).
Configuration  register is 0x2102
VAL-IPB-RTR-003#
VAL-IPB-RTR-003# sh  proc cpu | i CPU
CPU  utilization for five seconds: 99%/1%; one minute: 99%; five minutes:  72%
220            0         2          0  0.00%  0.00%  0.00%   0 SLB Main CPU  pro
277       40076   25601858          1  0.00%  0.00%  0.00%   0 Max CPU  utilizat
VAL-IPB-RTR-003#sh  proc cpu | i SNMP
  29           16       107        149  0.00%  0.00%  0.00%   0 Cat6k  SNMP
  30         1244      1117       1113  0.00%  0.00%  0.00%   0 Cat6k SNMP  Trap
158            0       126          0  0.00%  0.00%  0.00%   0 SNMP  Timers
302            0         2          0  0.00%  0.00%  0.00%   0 EEM ED  SNMP
311    39506708  321176354        123  0.07%  0.08%  0.02%   0 IP SNMP
316   367797992 401044214        917 94.90% 30.84%  7.60%   0  SNMP ENGINE
317            0         1          0  0.00%  0.00%  0.00%   0 SNMP  ConfCopyPro
318     1266468     250441       5056  0.00%  0.00%  0.00%   0 SNMP Traps
VAL-IPB-RTR-003#sh  stack 316
Process 316:  SNMP  ENGINE
  Stack segment  0x52B6DC78 - 0x52B70B58
  FP: 0x52B70528,  RA: 0x40FE1228
  FP: 0x52B70550,  RA: 0x40934C50
  FP: 0x52B70578,  RA: 0x40934D80
  FP: 0x52B705B0,  RA: 0x40937DC4
  FP: 0x52B70608,  RA: 0x41FC8038
  FP: 0x52B70680,  RA: 0x41FC8C0C
  FP: 0x52B706F0,  RA: 0x41FC7084
  FP: 0x52B70710,  RA: 0x41FC6214
  FP: 0x52B70988,  RA: 0x40E4FDF8
  FP: 0x52B709D0,  RA: 0x40E300CC
  FP: 0x52B70A38,  RA: 0x40E23184
  FP: 0x52B70AB8,  RA: 0x40E477C0
  FP: 0x52B70B20,  RA: 0x40FD750C
  FP: 0x52B70B38,  RA: 0x40FD74F8
VAL-IPB-RTR-003#
Thank you Sir.
Hi Joseph,
Could you please tell us how did you manage to idenfiy that the problem is related to VNM Mib ? Is it through the show snmp stack command ? i
Thank you
Zied
Hi  Joseph,
Just to explain we have exactly the same problem. Below is the show stack. Could this be related to the same VNM pollin
*Sep  5 12:02:43.230 GMT+1: %SYS-1-CPURISINGTHRESHOLD: Threshold: Total CPU Utilization(Total/Intr): 56%/14%, Top 3 processes(Pid/Util):  557/39%, 488/1%, 555/0%
*Sep  5 12:02:43.286 GMT+1: %HA_EM-4-LOG: CPUTH:
Process 557:  SNMP ENGINE
  Stack segment 0x1CFC204C - 0x1CFC4F2C
  FP: 0x1CFC49F0, RA: 0x9993528
  FP: 0x1CFC4A10, RA: 0x8C04F84
  FP: 0x1CFC4A20, RA: 0x8BEC170
  FP: 0x1CFC4A50, RA: 0xAB76E48
  FP: 0x1CFC4A58, RA: 0xAB773F8
  FP: 0x1CFC4A68, RA: 0xAB7776C
  FP: 0x1CFC4AA0, RA: 0xAE27A84
  FP: 0x1CFC4AB8, RA: 0xAFC75F4
  FP: 0x1CFC4AC0, RA: 0xA59A7AC
  FP: 0x1CFC4CF8, RA: 0xA5A38A8
  FP: 0x1CFC4D30, RA: 0xA59F194
  FP: 0x1CFC4DA0, RA: 0x973D4C0
  FP: 0x1CFC4E08, RA: 0x970BA00
  FP: 0x1CFC4E90, RA: 0x96F711C
  FP: 0x1CFC4F18, RA: 0x9729654
  FP: 0x1CFC4F20, RA: 0xAFAFF94
  FP: 0x0, RA: 0xAFAA270
Thank you
Please start a new thread for your issue.  When you do, include the output of "show version".
